20 Most Recent
Abit BE6-II Motherboard Questions & Answers
Computer gives long beep no bios screen
Although motherboard beep sounds depend on the type of CMOS/BIOS (like AMI, PHOENIX, IBM, AWARD BIOS etc) - still long beep is because of RAM failure. Please first remove the RAM - clean the RAM and slot well - re-install it - you may try in the different slot also. If it does not work you must use another RAM (the frequency should match).
Password
Unplug the power cord from the PC. Open you're case & find the 3.0v battery on the board. Use a flat tip screw driver & remove the battery. Wait about 15 seconds & replace the battery. Close the case & plug the power cord back in. Boot the PC. You will need to enter the bios to reset the clock settings & any other settings you may have made. Thats it.
Mike
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Kds monitors support
Hi Klex,
I was able to find the website address
www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
