20 Most Recent Delta & Soap Dispenser Questions & Answers
Soap dispenser will not dispense when pumped more
call delta they have a lifetime warranty and will replace it.
11/22/2015 7:53:34 PM • Delta & Soap... • Answered on Nov 22, 2015
0answers
My towel bar won't stay tight
maybe you need new screws in the bar?
1/11/2013 8:11:01 PM • Delta & Soap... • Answered on Jan 11, 2013
Just received my Delta Leland
i do not know a site that can help out but i am certain you can call delta for clarification on installation. there may also be a youtube video.
12/22/2011 1:03:30 AM • Delta & Soap... • Answered on Dec 22, 2011
Purchased soap desp. model #RP47280SS
bobj50-
The white washer goes underneath the counter (with the nut) and the rubber gasket on top of the counter under the dispenser head. You may find it easier to tighten the assembly with this configuration. As for filling the bottle, unfortunately it must be unscrewed from under the counter in order to refill it.
Hope this helps.
Regards,
DIYpro
5/17/2011 10:59:44 PM • Delta & Soap... • Answered on May 17, 2011
2answers
Brand new delta single handle shower valve won't shut off
If your new Delta single handle shower valve won't shut off, it could be due to an issue with the valve itself or with the installation. Some possible causes include a misaligned handle, debris in the valve body, or a faulty cartridge. It is best to check the installation instructions and ensure that everything is properly seated and aligned. If that does not solve the issue, you may need to contact Delta customer service for further assistance or consider hiring a plumber to diagnose and fix the problem.
1/23/2023 6:03:43 AM • Delta Home • Answered on Jan 23, 2023
My Delta Monitor shower faucet turns from 0 to 180, the water "stops" at 180 but you can continue to turn the handle more and the water will start again..
no info generic answer ---if have the manual it shows how to adjust the temp stops --look up manual using make and model
4/9/2022 1:28:56 AM • Delta Home • Answered on Apr 09, 2022
New delta diverter won't shut spout off completely.
Check there is nothing on the valve seating stopping the valve from shutting off fully
8/30/2021 4:05:59 PM • Delta Home • Answered on Aug 30, 2021
4answers
How can I remove a Delta faucet handle that has no set screw?
Use the special tool for pulling handles.
4/6/2021 8:28:26 PM • Delta Home • Answered on Apr 06, 2021
2answers
Our delta toilet keeps ghost flushes what part could be bad
1. Fill valve 2. Flapper
4/1/2021 3:08:23 AM • Delta Home • Answered on Apr 01, 2021
Need insructtins for delta in2ition shower head
Contact Delta directly to request.
3/28/2021 11:07:17 PM • Delta Home • Answered on Mar 28, 2021
Delta II urinal continues to flush after replacing the diaphragm
Refer to instructions that came with valve body, orgo on line and read them CONTINUOUS FLUSHING:1.The Regulating Screw (061024A, item #4) may be turned RIGHT (clockwise) TOO FAR. Adjust by slowly turning the Regulating Screw LEFT (counter- clockwise) (except -6, -48, -42, -19 and -05 models which are fixed volume).2.If flush is still continuous, close inlet stop, remove Regulating Screw (061024A, item #4), CLEAN bypass slot in the Screw, REPLACE it in the valve and Adjust slowly for proper flush (except -6, -48, -42, -19 and -05 models which are fixed volume).3.CHECK the relief valve in the Handle Cage (060810A, item #12) and see if it is stuck in the open position or fouled by debris. Replace the Handle Cage(060810A, item #12) if necessary.4.Remove cast cap assembly (see Table 1) and Diaphragm/Guide Assembly (061323A - WC, item #7a or 061324A - UR, item #7b, 061376A - UR,item#7c) and check for contaminants at renewable seat and diaphragm and check for debris in the cap for blockage. Also CHECK that the Diaphragm/Guide slides easily in the Renewable Seat.
6/7/2019 1:36:28 PM • Delta Home • Answered on Jun 07, 2019
I want to remove the flow restrictor in the Delta a112.18M shower head handle. Any advice how to remove it?
Most modern shower restrictors are permanently fixed and require some prying with a pick or small screwdriver and possibly drilling. Be careful that in removing some of the pressure reducing stuff you do not slip and put a hole in yourself. You don't have to get it all out, just enough to allow full pressure to the head.
5/17/2019 6:06:18 AM • Delta Home • Answered on May 17, 2019
My delta in2ition the hand held head is not working. I've only had it for 6 months. Water has totally stopped coming out.
Clean hand held the unit is probably clogged . If you have ard water you can soak it vinegar for a couple of hours.
5/16/2019 2:25:33 PM • Delta Home • Answered on May 16, 2019
How to adjust hot water temperature on Delta single handle shower valve
If I am reading this right. You have one single handle that controls the temp and flow in your shower, correct? This being the case and you cannot adjust the HOT down enough with the handle. Then my suggestion would be to turn it down at the water heater. If you remove the access door on the side of the unit. There should be either a dial you can turn with a small flathead screwdriver. Or a switch that selects the desired temp. But take into consideration that this will effect ALL water temp throughout your house. Washing machine, Dishwasher, etc.................. There might be one other thing to investigate as well. Look into the cold water supply side at the water heater. It might not be open all the way. Thereby restricting the cold water flow..........:) Good luck, Jason
5/10/2019 8:15:36 AM • Delta Home • Answered on May 10, 2019
I have a delta flush iq toilet,, my toilet wont flush, button will turn blue but then flash red, even if i manually flush from inside, i have to add water to tank to flush, whats wrong??
overflow protection. Read manual bacnwa8baibrwa8bwcnwqwaa4brwqwbwcvwqaac4xnl9unfrwxt95dr1fy8wiahkl35f31i2beekvwocigg16ivbx2mwzil+sdntearbearbr4dghyaigiaiwu2ch4igciigalvrkx7o55lzciigcikgv0zl8umaaaaaakst+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhbghwaaaacw2oefagaaambqb34iaaaaaksd+ceaaaaarhb+f8you7p28f70aaaaaelftksuqmcc https://media.deltafaucet.com/MandI/76687%20Rev%20D.pdf
12/29/2018 1:38:54 AM • Delta Home • Answered on Dec 29, 2018
2answers
I have a recently installed Delta 68816 shower head that was working well, but now, the handheld portion has lost water pressure. I barely get a dribble. What is wrong?
Guessing you have hard water. Is there there white crusty stuff around the little holes? If yes, take the head off and put it in a bowl of vinegar for half an hour or buy CLR. Either should soften or dissolve the lime. OR When you take the head off check the little filter screen for dirt. If the water has been off recently, the rush of water gilling the pipes again can stir up any dirt in the pipes. Take the screen out, clean and replace.
12/22/2018 7:37:49 AM • Delta Home • Answered on Dec 22, 2018
I have a Delta scald
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
10/20/2018 5:37:48 AM • Delta Home • Answered on Oct 20, 2018
Delta multichoice valve shower tub system problem-the system progressively lost pressure. i replaced the unit with a new delta series 13/14 with a slight improvement in pressure but still not normal.
check water lines for build up and shower haed remove and do same and clean inline filter if one present
10/20/2018 5:36:33 AM • Delta Home • Answered on Oct 20, 2018
Delta & Soap Dispenser  Logo
8 questions posted
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
View Most Popular
Delta Home
  • Delta Home
Most Popular Question
towel bar won 39 t stay tight
  • Home
