20 Most Recent
Abit AI7 Motherboard Questions & Answers
No beep but,fans are spinning
make sure the graphics card is seated all the way down. Perhaps remove it and then reseat it. If you are using the built in graphics i'll have to think os something else.
10/23/2013 3:36:40 AM •
Abit AI7...
Answered
on Oct 23, 2013
Hi I am working on
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
- No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
- One beep - board is working fine
- One long beep then machine shuts down - faulty, improperly installed or missing CPU
- 1 short(Beep) System booting is normally
- 2 short(Beep) CMOS setting error
- 1 long - 1 short(Beep) DRAM ERROR
- 1 long - 2 short(Beep) Display card or monitor connected error
- 1 long - 3 short(Beep) Keyboard Error
- 1 long - 9 short(Beep) ROM Error
- Long(Beep) continuous DRAM isn't inserted correctly
- Short(Beep) continuous POWER supply has a problem
- A two-tone siren, generally caused by overheating or out of specification voltages
- Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
9/8/2011 12:08:30 AM •
Abit AI7...
Answered
on Sep 08, 2011
Have an Abit A17 motherboard
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
7/15/2011 2:26:00 AM •
Abit AI7...
Answered
on Jul 15, 2011
No sound in computer system
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
:also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar:
if his does not fix the
problem
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer: hope this
helps
7/9/2011 8:23:29 AM •
Abit AI7...
Answered
on Jul 09, 2011
My computer stopped working suddently.
Try checking your power supply or swapping it with one from another computer. See if the low siren noise is coming out of the power supply or off the motherboard. That noise is usually a bad capacitor on the circuit. If it is on the motherboard you would need to replace it.
Let me know what you find, Thanks for using FixYa
5/14/2011 1:52:43 PM •
Abit AI7...
Answered
on May 14, 2011
System powers up for a
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
10/26/2010 3:31:55 AM •
Abit AI7...
Answered
on Oct 26, 2010
What is post code AF
Code AF usually refers to memory especially if it comes with a long beep instead of the normal quick beep.
If you have recently added memory remove the new stick and reboot. If all is well then the new stick is not compatible with the old one or with the motherboard.
If no memory has been added recently then try removing your memory stick and re-inserting it, it may not be seated firmly in place or, if you have more than one
stick, fit them one at a time to rule out any compatibility problems, or
errors with one or other of them.
Another thing that will throw a code AF is the processor, make sure the processor is firmly seated under the cooling fan and that there is the proper amount of cool seal between the fan and the top of the processor. BE VERY CAREFULL when working near the processor as a static discharge can and will destroy the processor and don't bend any of the pins on the processor base. If not familiar with working with a processor DON'T. Take it to someone who is.
10/9/2010 12:54:26 AM •
Abit AI7...
Answered
on Oct 09, 2010
A17
What is the problem?
8/9/2009 5:06:46 PM •
Abit AI7...
Answered
on Aug 09, 2009
Two tone Siren from MoBo/over heating CPU
at first go to the bios. then default the bios setting. then check the system monitor. if the cpu is too hot you can see it. or you can change the processor. never over clock the processor.
1/20/2009 8:19:43 PM •
Abit AI7...
Answered
on Jan 20, 2009
A17 wont boot
ok what board is it
#then check the manual for error post code error af
if not try another card liek a pci one
or agp one
6/7/2008 12:11:24 PM •
Abit AI7...
Answered
on Jun 07, 2008
DIAGRAM
Need more info as there were a few diff versions. Need the full abit part number and chipset type.
Use cpu-z to find out info :)
1/6/2008 9:34:06 PM •
Abit AI7...
Answered
on Jan 06, 2008
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
