20 Most Recent Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker Questions & Answers
My water has a lot
Not on the refrigerator, only where the water comes out of the wall to your refrigerator. First make sure the line is not clogged by removing the filter and making sure you have water flow through the hose. Then reattach the filter to the hose only and then make sure you have water through the hose and filter (may get a little messy). Then attach the filter to the refrigerator to see if you have flow. If you do not then your refrigerator water lines are clogged. Here is a video that shows how to fix problems like this:
11/21/2017 2:43:46 PM • Kenmore 21.7 cu.... • Answered on Nov 21, 2017
Our freezer section does not
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
I hope this will help in solving the problem.....
11/27/2014 7:13:41 PM • Kenmore 21.7 cu.... • Answered on Nov 27, 2014
2answers
Kenmore Elite top mount refrigerator getting ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
10/3/2011 9:19:30 PM • Kenmore 21.7 cu.... • Answered on Oct 03, 2011
Leaking water inside of refrigerator. Ice maker
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
8/27/2011 5:06:19 PM • Kenmore 21.7 cu.... • Answered on Aug 27, 2011
FROST BUILDUP AND NOT MAKING ICE. THINKING ITS THE
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/10/2011 12:23:10 AM • Kenmore 21.7 cu.... • Answered on Aug 10, 2011
Where is the drain in
If you look at the picture below, it is number 24. It is called a drain tube and attaches to the rear of the unit on the right hand side (when looking at it from the rear).
7/31/2011 4:20:01 AM • Kenmore 21.7 cu.... • Answered on Jul 31, 2011
I have a Kenmore 106 77292790 Top-Mount
You said you replaced the timer and have the thermostat on order, but you didn't say if you had checked the heater element
Heater
PART NUMBER: 2166124
Substitution: 2315530
Since those are the three components of the defrost system! If the timer and thermostat both work perfectly, if the heater is open, there is nothing to defrost the evaporator coil.
You should also check your fan motor http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/4387244/0046/106/Model-10677292790/0582/0166000?keySuffixId=NA&productTypeId=x&searchModelNumber=10677292790&subCompDesc=Unit%20parts&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11 and make sure it is operational.
7/12/2011 7:12:53 PM • Kenmore 21.7 cu.... • Answered on Jul 12, 2011
The freezer works well but the fridgedoes not get
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
6/5/2011 5:20:19 PM • Kenmore 21.7 cu.... • Answered on Jun 05, 2011
0answers
Our top mount refrugeratir model 106'74212402 is
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
8/30/2010 4:09:24 AM • Kenmore 21.7 cu.... • Answered on Aug 30, 2010
2answers
TOP MOUNT FRIDGE WATER LEAKING INSIDE OF UNIT UNIT
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
8/30/2010 1:03:58 AM • Kenmore 21.7 cu.... • Answered on Aug 30, 2010
Ice maker not working. Refrigerator had been off
Hello there
f your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
7/26/2010 4:36:37 PM • Kenmore 21.7 cu.... • Answered on Jul 26, 2010
Top mount freezer drain keeps freezing up causing
Check the Evaperator Fan in freezer for correct operation low air flow will cause the problem. Check defrost timer, heater and limit thermostat, If it is not defrosting correctly it will cause the problem.
3/29/2010 6:13:35 PM • Kenmore 21.7 cu.... • Answered on Mar 29, 2010
Water has been pooling at bottom of frig. drain
still making ice? if so not i/m. the ref at some point was too cold thus freezing drain in inner wall. no easy way to get to it. unload, leave unpluged and open for 24 hrs. Set at mid scale on both controls then put back into service
8/26/2009 11:46:21 AM • Kenmore 21.7 cu.... • Answered on Aug 26, 2009
Water standing under drawers of Kenmore fridge
More than likely the working end of that drain tube is located just above the compressor where the water can drip into a pan on top of the compressor and help keep the compressor cool.Get some compressed air and blow it out at that point AFTER you thaw out the ice box. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/4/2009 2:53:23 AM • Kenmore 21.7 cu.... • Answered on Jan 04, 2009
Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker Logo
39 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
drain in
  • Refrigerators
