20 Most Recent Kenmore 55693 Side by Side Refrigerator Questions & Answers
2answers
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
12/5/2014 6:41:47 PM • Kenmore 55693... • Answered on Dec 05, 2014
I have whirlpool refrigerator 6wmv43ns/02 it won't do defrosting
Replace bimetal and defrost timer
11/7/2013 2:56:42 AM • Kenmore 55693... • Answered on Nov 07, 2013
LG stopped making ice. Turned
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
7/31/2011 6:10:01 PM • Kenmore 55693... • Answered on Jul 31, 2011
0answers
How to make ice maker to stop making ice. I
if you want it to STOP,,,,making ice. there should be a valve on the water supply line to shut off
10/31/2010 3:33:35 AM • Kenmore 55693... • Answered on Oct 31, 2010
Kenmore icemaker making too much ice
you need a new icemaker
9/28/2009 10:47:20 PM • Kenmore 55693... • Answered on Sep 28, 2009
Ice maker will not shut off
lift up on the shut off arm.it's the long wire on the side of the ice maker
8/17/2009 12:59:53 AM • Kenmore 55693... • Answered on Aug 17, 2009
Ice maker keep making ice
It will not cut off unless the arm is raised to the highest position and will lock unless it is broken.
7/7/2009 3:08:45 PM • Kenmore 55693... • Answered on Jul 07, 2009
My sears refrigerator has an ice maker that will not shut off
You will have to remove the icemaker from the freezer so you can see if the plastic is broken that holds the arm in position.
7/7/2009 3:06:20 PM • Kenmore 55693... • Answered on Jul 07, 2009
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
7/7/2009 3:03:02 PM • Kenmore 55693... • Answered on Jul 07, 2009
If your shutoff arm stays up, the switch inside is bad. Usually have to replace the entire icemaker. Send model # from tag on fridge for part lookup. hope this helps!
1/5/2009 2:42:56 PM • Kenmore 55693... • Answered on Jan 05, 2009
souonds like that sensor has gone bad, doenst know its full and contionues to make ice. youll need to repalce the electronic board.(they come as a kit both emitter and reciever,)
3/8/2008 3:35:03 AM • Kenmore 55693... • Answered on Mar 08, 2008
2answers
Coldspot 106.51133210. How can I select diagnostic mode?
air damper motor control has failed , call a local repair service
4/13/2024 4:57:12 PM • Kenmore... • Answered on Apr 13, 2024
What is the cubic feet of kenmore coldspot model 106.59599993
The Kenmore Coldspot 106 is a 20.7-cubic foot side-by-side refrigerator with a reverse osmosis Pure water filter, ice maker and digital controls. ..
4/10/2024 12:02:42 AM • Kenmore... • Answered on Apr 10, 2024
Kenmore Refrigerator 795.75004401. The freezer seems to be working fine but the fridge part is not. Checked the condenser coils and they are free of dust. The condenser fan is working as well.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an Refrigerator Evaporator Fan Motor. The part is obsolete anyway. If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/ This shows all the parts. https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts ..
4/7/2024 5:30:26 PM • Kenmore... • Answered on Apr 07, 2024
Kenmore 55693 Side by Side Refrigerator Logo
Popular Tags
32 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
lg stopped making ice turned
  • Refrigerators
