20 Most Recent Kenneth Cole KC3289 Wrist Watch Questions & Answers
  • The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
  • Hope this helps.
Kenneth Cole... | Answered on Nov 26, 2011
mcdevito75 Here, You"ll need a tool called a spring bar remover tool available on ebay, but by the time you get the tool you can have a small watch repair shop in your area replace the band and for about the same money as the tool.
Kenneth Cole... | Answered on Feb 06, 2011
The arrows indicate the direction that the pins punch out. Its possible that it has tiny little sleeves that put pressure on the band which hold the pin in. Take it to a reputable watch repair shop...they can assist you with your adjustment! :-)
Kenneth Cole... | Answered on Jan 17, 2010
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Kenneth Cole... | Answered on Mar 11, 2009
some watches have a special way to open..nut by push/pull out the back but by rotating it .in this case it hase some small cuts in the back cover .if this so,it just might need to rotate.
Kenneth Cole... | Answered on Sep 06, 2008
WE DONT VALUE ANYTHING HERE SORRY
Kenneth Cole... | Answered on Sep 13, 2019
Take the watch to a jeweler for a demonstration.
Kenneth Cole... | Answered on May 13, 2019
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
Kenneth Cole... | Answered on Feb 18, 2019
Maybe a reset button inside marked a.c. if so short it between battery and a.c. button.
hope this helps
Kenneth Cole... | Answered on Dec 21, 2018
Type, not size. Take your Kenneth Cole watch to a jeweler who will open it and identify type.
Kenneth Cole... | Answered on Nov 19, 2018
Try Googling (Kenneth Cole)(kc8041)(manual) without parens.
Kenneth Cole... | Answered on Mar 17, 2018
Kenneth Cole KC3289 Wrist Watch Logo
9 questions posted
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Norman Worley
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Kenneth Cole Watches
Most Popular Question
shortening length metal wrist band
  • Watches
