20 Most Recent
Wave Audio CS801 Speaker Questions & Answers
I have no sound coming from home theatre system
I would check see if you can hear any hissing coming from the speakers if there's no sound then check to see if this product has output protection fuses and if so see if they are in tact if this doesn't solve the problem you may have dead outputs. If there is hissing coming from the speakers check your audio source to make sure it is feeding sound to your amplifier without looking its hard to say in these case's there's a lot to go wrong
Home speakers
1st of all i would take a multimeter and test each wire to make sure you have a connection after this i would use any amplifier connecting 2 speakers at a time locating each one and then label the cables then from there buy a suited amplifier for your needs and away you go
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Hometheatre system and computer
There are A/V selector switches that allow u to plug in various devices and then switch to each device when wanting to use, I've got one! Amazon or Best Buy even Wal Mart (probably) have in various configurations.
Suround sound speeker system for sony
It's very simple. The center speaker should be directly in front of you, usually where the TV is located and the front left and right should be at the side of the TV (left and right), the two rear speakers should be anywhere behind you and the subwoofer can be placed anywhere in the room. The front speakers and center should be within 6' to 10 feet from the seating position and the rears can be anywhere behind the seated position.
Hope that helps.
Audio failure
On the desktop or from start menu, right click on "my computer".
Left click once on "manage".
Left click once on "device manager".
If there are and yellow excalamation marks in the device list you
don't have drivers installed for that particular device.
If the audio has exclamation you need to find the driver disc or
download audio drivers from the net.
Also make sure you have the speakers plugged into the green socket at rear of pc and that you dont have audio muted.
Cheer's Steve
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
