20 Most Recent Kenmore 63252 Microwave Oven Questions & Answers
2answers
How to set funtions of lg microwave model no. is
try to read your users manual on set the functions ok.
10/22/2021 2:29:17 PM • Kenmore 63252... • Answered on Oct 22, 2021
Where is the fuse on kenmore microwave
Is this an over-the-range (OTR) microwave oven or a counter-top model? Assuming it is an OTR model, your can get to the fuse by first unplugging the microwave, then removing 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, OR tilt out the top of it followed by the bottom. Now you should see 1 screw that hold the top of the control console in place. Remove it, then lift up on the control console to get past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it. Sometimes that fuse blows for no good reason, other times it blows because you have a shorted high-voltage capacitor, or you may have a sticking "monitor" door switch. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/25/2015 7:40:16 AM • Kenmore 63252... • Answered on Jan 25, 2015
How do I repair touch buttons
Usually those buttons are on a separate small board. Sometimes that board breaks loose from it's support tabs; other times the buttons just go bad with age and use, and you need to replace that button board. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/25/2015 6:43:39 AM • Kenmore 63252... • Answered on Jan 25, 2015
The turntable in my microwave will not turn.
cause you aint got the right beats
10/17/2014 6:07:13 AM • Kenmore 63252... • Answered on Oct 17, 2014
0answers
Microwave ran empty, can
check your door switches.
6/7/2014 2:09:40 AM • Kenmore 63252... • Answered on Jun 07, 2014
Wiring diagram for 363.62702200
There should be a technical sheet hidden behind the grille or behind the controller. It will show you how to connect it. The only wire that you can connect incorrectly is the one in the lower center of the board that connects to the black relay next to the small power transformer. Try rotating the connector 90 degrees if the oven is not coming on. Look at my profile picture for more help. 361af86b-6e54-4068-a151-42987098168d.jpg
12/28/2013 9:31:20 PM • Kenmore 63252... • Answered on Dec 28, 2013
Mine was made july of 2007 so it would be under
Typical warranty is 1 year parts and labor and 3 to 5 years on the magnetron tube only. BTW, what's wrong with this unit ??
11/15/2013 10:58:58 PM • Kenmore 63252... • Answered on Nov 15, 2013
Kenmore microwave 201KM00280
sears repaire them or has the parts
4/2/2013 12:15:34 AM • Kenmore 63252... • Answered on Apr 02, 2013
Microwave will not heat
check the reactor fuse
9/15/2012 12:53:16 PM • Kenmore 63252... • Answered on Sep 15, 2012
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
9/3/2012 4:39:50 PM • Kenmore 63252... • Answered on Sep 03, 2012
The paint came off because my grandaughter put aluminum foil in it. How can I repair the paint?
I would like to make a warning ,do not try to repair microwaves , they are lethal weapons , I know someone who ran one with the cover removed and cooked his kidneys , if it is faulty dispose and get new, if aluminium foil was put inside it has heated up and as you say damaged paint ,the seal could also be damaged and lethal , dispose and buy another .
3/22/2012 7:16:15 PM • Kenmore 63252... • Answered on Mar 22, 2012
I have kenmore microwave model 721.80012401 it does not heat, I checked the magnetron thermostat, capacitor and the only thing that does not check out is the diode,can the diode cause this problem?
yes your diode can keep it from heating but it usually makes a loud growling if diode is bad. there is also another thermal disc on the other side of the oven that could be open. usually can see it in a hole in the plastic with 2 wires. if there is continuity on both this and the mag thermal, you may have a bad magnetron
2/12/2012 4:01:02 AM • Kenmore 63252... • Answered on Feb 12, 2012
Kenmore 63252 Microwave Oven Logo
121 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
kenmore model 721 63352300 turn when
  • Microwave Ovens
