20 Most Recent
Saniflo Sanicompact 48 Toilet With Pump, White Questions & Answers
My saniflow toilet is blocked and a plumber has
If you hear it making noise the motor isnt blown, but it could be clogged. A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
9/8/2014 1:24:24 PM •
Saniflo...
Answered
on Sep 08, 2014
I have a sanicompact 43.
This are likely solution to stop the water leakage below
Clean tank ball and drain seat thoroughly. If leak persists, replace
the worn tank ball or flapper with a Fluidmaster Bull's Eye Flapper
Model 43 or 48, Bull's Eye Super Flapper Model 43/48 or a Flusher Fixer Kit
replacement seat for damaged brass, plastic or ceramic flush valve
drain seats.
Make certain the black vinyl refill tube is attached to the top of the
overflow pipe with the angle adapter (see illustration). If the angle
adapter does not fit onto the overflow pipe. Fluidmaster offers a
Special Refill Clamp Model 43/48
Reset to a lower level by using the water level adjustment clip (see
illustration) located on the link of the valve. Squeeze the two ends of
the metal clip together, then slide clip down the link.
Replace the entire overflow pipe/flush valve assembly.
Solution 2
Shut off the water supply and remove the Valve cap (Model 43 or 48: lift
arm first) by rotating 1/8 turn counterclockwise. Cover the opening
with an inverted cup, and turn water on and off a few times. This
should flush and remove water line debris. Turn cap over and clean seal
surface by rinsing under running water. Replace cap (43/48: lift arm
first) by rotating clockwise. Turn on water. In the case of well water
supplies, the best long-term solution is a filter.
Shut off main water inlet valve to the house. Turn on all water outlet
valves inside and outside the houise, then flush all toilets. Allow
outlets to drain and pipes to fill with air. Then turn on main water
inlet valve and fill and shut off inside and outside outlet valves.
Remove toilet valve caps (43/48: lift arm first) by rotating 1/8 turn
counterclockwise. Hold a container over the uncapped valve and turn
water supply on and off a few times to clear debris. Replace top by
engaging lugs and rotating 1/8 turn clockwise.
Thank you and thanks for using fixya.
10/12/2010 4:02:37 PM •
Saniflo...
Answered
on Oct 12, 2010
