20 Most Recent Porcher VENETO II One-Piece Toilet - 97220-00-001 - White Questions & Answers
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl through the flush valve slowly...causing the tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve needs a special wrench,to remove it, that you use with a ratchet. If you buy a new flush valve, it comes with the wrench (glorified piece of plastic) and is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the toilet type - a four digit number embossed in the tank starting with a 2. hope this helps but if you need anything else just ask:)
Porcher VENETO... | Answered on Jul 29, 2011
https://www.youtube.com/watch?v=FlJ3UQlkEdU
First you will need to obtain the kit or parts necessary for replacement, compare your parts to your existing before doing anything, you will need your model number and if you had a picture more help could be offered. Begin by turning off the water supply to the toilet, keep a small bucket handy to catch the water, disconnect the supply line at the toilet if your are doing a complete replacement. If its only the handle again a handle kit will need to be obtained for your specific model no need to turn off water but keep in mind your exact handle or button placement. When you have the correct parts its just a matter of remove and replace and take photos of before so you can reference what goes where if you get sidetracked.
Porcher Home | Answered on Nov 11, 2018
1 bolt or screw on both sides at the hinge , usually a snap off cover over them
Porcher Home | Answered on Nov 09, 2018
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Porcher Home | Answered on Feb 20, 2018
http://www.porcher-us.com/assets/documents/porcher/spec/SpecSheet_3362.pdf
http://www.guillens.com/POR/9712.htm
Parts breakdown.
Specs are above. Immediately below is the company site but they may only offer some support rather than directly providing any parts. I list a couple of possible sources for parts after that.
Welcome to Porcher
http://www.guillens.com/buy/product/97120-00-001/22791
Porcher Faucet Toilet Parts
Porcher Home | Answered on Dec 19, 2017
then replace the mechanism we can not do it for you .
Porcher Home | Answered on Sep 30, 2017
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
Porcher Home | Answered on Feb 18, 2017
Porcher VENETO II One-Piece Toilet - 97220-00-001 - White Logo
1 questions posted
Top Porcher Home Experts
Derek Bannister
Derek Bannister
ray gallant
ray gallant
bobalix
Are you a Porcher Home Expert? Answer questions, earn points and help others
View Most Popular
Porcher Home
  • Porcher Home
Most Popular Question
occasionally hear small leak coming
  • Home
