20 Most Recent
KitchenAid KGRT607 Gas Kitchen Range Questions & Answers
KitchenAid Gas Range Model KGRT:
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
My beep quit! Beep used to work when the oven came
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oven not setting temperature
need more info does it even get warm if it does but not to temp needs temp sensor if it wont light needs ignitor
Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my
KitchenAid oven for the first time. I wish I had read these forums and
simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
My oven does not want to heat up - it always stays on LO? can u help
Do the top burners act properly, meaning giving high heat? Are you seeing black soot or just low flames? Low heat all around possible the gas cutoff in the kitchen has been turned down accidently. not an expert but have experienced the same problem with my new gas stove. The valve was almost off.
