20 Most Recent KitchenAid A-9 Electric Burr Grinder Questions & Answers
0answers
It stopped grinding half way through a grinding
sounds like the shear pin is broken
8/1/2014 3:04:16 PM • KitchenAid A-9... • Answered on Aug 01, 2014
Think question cut off. Need to know how to remove "screw" in back to clean burrs. It is not a phillips head, maybe rivet.
there are a number of 'newer' drive configurations for modern fasteners specifically designed to limit consumers from doing their own servicing. Take the unit to your local tool dealer and get the proper tool. If it actually is a rivet, it will need to be drilled out and then replaced with a new one.
7/5/2014 6:46:16 PM • KitchenAid A-9... • Answered on Jul 05, 2014
My A-9 KA coffee mills are working perfectly. 2003 never quits, 2006 was a royal pain and burrs/pin replaced and working perfectly. Now, I have a 2004 used for decaf, actual use from purchase about
I don't see a question in the paragraph but common problems for the A9 are 1) Shear pin 2) Motor brushes 3) slow motor operation If shear pin then the grinders won't turn or may intermittently rotate if pin is half broken If motor brushes worn to nubs then a fast clicking noise and sporadic on off operation followed by no operation If motor is slow then the commutator may need cleaning requiring removing the rotor
7/3/2014 7:08:48 AM • KitchenAid A-9... • Answered on Jul 03, 2014
KCG200WH1 model
If you mean a chrome with serrated edges then that is a screw type ring that screws on the toggle switch on the outside to hold the switch tight in place against the body of the grinder. Place the ring over the toggle and hold the switch in place and screw the little ring on until tight.
4/7/2014 5:12:59 PM • KitchenAid A-9... • Answered on Apr 07, 2014
Reach/remove pin.
Patricia, I am not sure which model you have old or new. I have the old one built in the 30's. I had to replace the shear pin and the carbon brushes for the motor. I took the bottom off which has a ball bearing resting loosely in a cavity in the bottom plate. Don't lose it. Now the brushes I found at an ace hardware. Take the old ones to compare. I think there was a bracket holding the brushes and rotor in. Once the rotor was out you could get the brushes out. Putting the brushes in required figuring out how to keep the brushes retracted. I used a piece of paper and used it hold them back while sliding in the rotor. Once in pull the paper out. Now the shear pin needs to be in to prevent damage to the grinder in case what you are grinding has something too hard to grind like a small rock, I think if you push up on the rotor when the bottom plate is off or pulling up on the shaft it might give enough clearance to put the shear pin in. It sits very close to the bottom of the shaft so it can be fun trying to line it up. I used needle nose pliers to hold the pin just right while pulling up on the shaft. I bought the shear pin off of ebay
4/7/2014 4:44:54 PM • KitchenAid A-9... • Answered on Apr 07, 2014
Motor works, will not grind, need to replace
sounds like a broken shear pin..
3/29/2014 8:25:07 PM • KitchenAid A-9... • Answered on Mar 29, 2014
Motor quit running
I recently found one and it wouldn't turn so I took off the top burr and it would turn on so I would start with a thorough cleaning of the burrs then check the setting of the burrs, if they are too close the they wont allow the motor to run. Next if the motor runs but the burrs don't turn it would be a sheared shear pin which is designed to shear in case a pebble got in the coffee before damage could occurThird worn motor brushes. My motor was intermittent and found the brushes down to nothing. Now I am looking for new ones
6/28/2013 5:57:53 AM • KitchenAid A-9... • Answered on Jun 28, 2013
Can not turn the grind
Same thing happened to me. It turned out the cause was a build up of hardened coffee grounds. We took it apart (a bit tricky!) and cleaned it. Now works like new.
11/20/2012 3:04:36 PM • KitchenAid A-9... • Answered on Nov 20, 2012
I can no longer turn
Same thing here. We ended up taking it apart. Took a bit of time and a few tools, but basically the oils from coffee 'gum up' the parts. I couldn't get it to turn to FINE, as dial was stuck. I had two handy guys that did it for me. A pair of pliers and a screwdriver were involved. There was some really hardened chunks of coffee that had caused it. Works like new now!
11/20/2012 3:00:30 PM • KitchenAid A-9... • Answered on Nov 20, 2012
2answers
My A-9 Coffee grinder no longer grinds coffee.
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
11/22/2011 8:30:31 PM • KitchenAid A-9... • Answered on Nov 22, 2011
KitchenAid A-9 Electric Burr Grinder Logo
Popular Tags
52 questions posted
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Coffee Makers & Espresso...
  • KitchenAid Coffee Makers & Espresso...
Most Popular Question
kcg200wh1 model
  • Coffee Makers & Espresso Machines
