20 Most Recent KitchenAid KHMS105EBL Microwave Oven Questions & Answers
Can I field replace a membrane switch on a Kitchenaid Microwave
Yes! so long it is the correct part and make sure unit is unplugged for safety, "lethal voltages" if unsure call a professional.
4/3/2012 10:49:33 AM • KitchenAid... • Answered on Apr 03, 2012
No power to microwave,but outlet
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';'';';';
5/20/2011 2:28:57 AM • KitchenAid... • Answered on May 20, 2011
Microwave and display panel are not working. There
Since you posted this under model KHMS105EBL, I'll assume that's your model number.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number with no dashes).
You can also find helpful exploded views and order parts here.
This model has a line fuse, an oven cavity thermostat, and a magnetron thermostat, any of which can render the oven "dead".
If those components are good, then you may a problem with the control circuit board. More info here.
Accessing some components (like the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
If you need more help, let us know.
8/19/2010 1:19:18 AM • KitchenAid... • Answered on Aug 19, 2010
Kitchenaid microwave kmhs120ess door fell apart
Doors for microwave ovens are usually replaced as a complete item. I would ask the person who forgot to fix the door latches properly back to fix it properly. If some of the clips were snapped off when removing the door panel, the panel must be replaced or it will fall out again.
2/11/2024 9:28:54 AM • KitchenAid... • Answered on Feb 11, 2024
Kitchenaid oven racks fall
I am a bit late on this question, but just ended up in a rabbit hole of unanswered Kitchenaid questions The self cleaning features only serves to keep manufacturers in steady sales of parts. Quite simply the oven can only take those temperatures a few times until they break. The heat burns out elements, damages fans, door locks and worst of all damages control boards which are not far enough from the heat source. You problem sounds like the walls of the oven have buckled in the heat so the racks no longer fit. Too late now, but you should have taken Kitchenaid to court, the oven was not fit for purpose under the description they used to sell it to you. Never use the self cleaning feature as stated here https://www.google.com/search?q=self-cleaning+oven+temperature Never Ever use the self clean feature. We see damage here every couple of weeks. The worst was a burned control board on an oven that all parts were obsolete, so the self clean cost a thousand bucks! Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (Says Maytag who love selling elements, door locks and other parts),
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Servicehttps://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipediahttps://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CAhttps://fixappliances.ca > 4-reasons-stop-using-self-cle... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
1/16/2024 4:40:22 AM • KitchenAid... • Answered on Jan 16, 2024
My KitchenAid oven/microwave combo KEMC377KSS05 control panel not working. how to check what is wrong?
Open the control panel using this diagram Official KitchenAid KEMC377KSS05 wall oven/microwave combo parts ' Sears PartsDirect Check the cables and connectors. If Ok then problem is in cuicuit board.
10/18/2023 1:27:43 PM • KitchenAid... • Answered on Oct 18, 2023
KitchenAid Superba KEMC308KSS0 Microwave oven acting like we're having repeated powerline brown-outs, but we're not.
There is a huge capacitor inside microwaves, and that description sounds like it is starting to fail. There are smaller capacitors as well. It won't be a door switch, they work or they don't. I had two Panasonic Commercial microwaves in a pub kitchen, one plain and one was a combination machine and both had drop down doors.
5/20/2022 1:57:13 AM • KitchenAid... • Answered on May 20, 2022
2answers
Can I disable the beeping/tones on my Kitchenaid microwave?
I'm not familiar with that particular model, but with many of their models (and many other manufacturer models as well), unfortunately the beep cannot be turned off.
5/12/2022 2:55:57 PM • KitchenAid... • Answered on May 12, 2022
KitchenAid KMHS120ESS Microwave. Where can I find the wiring Schematic for it?
Question moved from Cars and Trucks category. No wiring schematic exists, but this does show there is an internal fuse. https://www.repairclinic.com/ProductDetail/2145587 Service manuals aren't generally available, because the insides are so dangerous! Keep away from the step up transformer and capacitor with 120,000 volts stored in it. https://www.google.com/search?q=kitchenaid+kmhs120ess+service+manual& https://www.google.com/search?q=kitchenaid+kmhs120ess+wiring+diagram&rlz=1C1QJDB_enCA643CA644&sxsrf=APq-WBu2IViisg_YzIUbx0IaRs0iQu4SNw:1648409430308&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiDuqbUg-f2AhUaac0KHd1pAb8Q_AUoAnoECAEQBA&biw=1920&bih=937&dpr=1 ..
3/27/2022 7:31:44 PM • KitchenAid... • Answered on Mar 27, 2022
Kitchenaid KEMS308SSS00: when I open the microwave door now, instead of light coming on, the turn table turns!
It's a guess, but something mis-connected on that new board. They usually have a number of edge connectors and you have two on the wrong pins. A guess never the less.
3/1/2022 8:28:40 PM • KitchenAid... • Answered on Mar 01, 2022
KCMS145JSS kitchenaid microwave start button doesn't work unless I hold it down the entire time it's on.
sounds like Touch pad/Keypad/Membrane Switch is bad or control panel is bad. You can go online and using your model number search for parts, or have it repaired. If your order parts do you have the skill, knowledge and tools to do job? You could end up throwing parts at it. Personally I would weigh the cost of repair plus the age of unit versus a new one.
1/11/2022 4:26:01 PM • KitchenAid... • Answered on Jan 11, 2022
2answers
Fuse location on kitchenaid kmhs120ess-4 over stove microwave/fan combo unit
You can find helpful Kitchenaid parts diagrams and get parts at affordable prices for most models from The Pros by entering your model number here:
http://tinyurl.com/gv383
11/16/2021 10:11:30 PM • KitchenAid... • Answered on Nov 16, 2021
2answers
How do I remove door on KitchenAid microwave YKHMS2050SS-2 in order to replace the CTRL-ELEC control card inside the door?
For the KitchenAid microwave, model: KHMS2050SSS2 I found that i did not have to remove the screw. what i did was loosen the screw as much as it would go before getting tight again.(hard to screw) then on the bottom end of the door hinge (lying on its side) i pryed the bottom hinge off its mount. (with flat head screwdriver) from there i was able to get at the screws to separate the black surrounding stuff from the outside door... then finally i could get inside to get at the door panel controls. I noticed a whole bunch of condensation and on the back of the touch panel (electrical board).. i will replace that part as I think that is the culprit as to why the keys get pressed randomly, beeping randomly and wonkiness :)
4/24/2021 6:22:26 PM • KitchenAid... • Answered on Apr 24, 2021
2answers
I have a Kitchenaid built-in microwave, model KBMC147HSSO that seems to run OK but will not heat. I suspect it is a bad magnetron. The oven is nearly 17 years old.
I have a Kitchenaid microwave KCMS145JSS0 that had a loud buzzing sound, stopped heating and there was a smell of burning electronics. It is about 19 years old, but can not be replaced because it is built in and you can not find a microwave anywhere that will fit in the opening of the 24 inch cabinet. So I had to fix it. Turns out the problem was the Magnetron. This is what I did to prove the problem. First open the unit, discharged the high voltage capacitor with a short across the terminals using a test lead from my VOM analog meter. Next disconnected the connector to the Magnetron and started the microwave. The buzzing sound was gone. Powered off the microwave and again discharged the capacitor. Using my VOM on the highest ohm value tested between the terminals on the Magnetron to ground and had a reading, it should not read anything, it should read open or infinity - Magnetron Bad. Just to make sure the other high voltage components were good I performed the following tests. Checked for continuity of the 3 different circuits on the high voltage transformer, all were good. Tested the capacitor by removing all the leads connected to it and discharged it once more. With the analog VOM set to the highest value, touched the two terminals on the capacitor. The meter should swing to the right and move back to the left as the capacitor takes on a charge. Did that just fine. There is a high voltage diode connected to one of the capacitor terminals and the other end to ground. With the analog VOM set to the highest ohm setting touched the meter to the disconnected end and ground and got a reading. Reversed the meter test leads and didn't get a reading, infinity. I was very confident the Magnetron was my only issue but decided to replace the diode along with the Magnetron because it was $20 compared to the $160 Magnetron and I had that smell of burning electronics. With the new parts the microwave now works great and no need to reconfigure the cabinet installation.4ae0592f-2f48-49d0-887b-5e06be0f2b42.jpgimg_20201115_120324276-gbuu514lwj4gf3zniqowptdg-6-2.jpg
11/19/2020 1:23:17 AM • KitchenAid... • Answered on Nov 19, 2020
2answers
KitchenAid Microwave Touch pad stopped working. Spoke to a technician and told me that you have to replace the complete door. Is this true??? Part No. AP4500800 Mfg Part Number W10282802 Microwave mo
You must presume Tech knows what he is talking about , but get 2nd opinion, then you will be sure.
4/6/2020 1:19:34 PM • KitchenAid... • Answered on Apr 06, 2020
Would I find the wiring Schematic inside my KitchenAid YKMLS311HBS Microwave?
Yes, unless a technician may have removed it during a previous service. It should be located behind the controller assembly, sometimes in a small envelope.
At my Web site, I have a video showing you how to remove a typical microwave controller in about 5 minutes.
http://www.microwavecontrol.com
if you have other questions, please feel free to contact me directly by email through the Web site or at [email protected]
11/14/2019 1:57:44 AM • KitchenAid... • Answered on Nov 14, 2019
Microwave Ovens Logo
8 questions posted
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
field replace membrane switch kitchenaid
  • Microwave Ovens
