20 Most Recent
Homelite Gas Pressure Washer: 2700 psi 2.3 GPM UT80522D Questions & Answers
Need a fuel line diagram for my Homelite vac attack 2 model UT09834
You should have 2 lined coming from tank. A return and feed. Normally the return is the lowest positioned outlet on the carb, and the feed is at the top. When pumping the purge bulb take the gas cap off tank, and you should see fuel being returned to the tank from the return line. If not, switch the lines on carb. If still not returning fuel to the tank, you will need to pull the carb and inspect the metering and fuel pump diaphrams.
What is the spark plug gap for a homelite 2700psi pressure washer with champion eco 322
The recommended spark plug gap for a Homelite 2700 PSI pressure washer with a Champion Eco 322 spark plug is 0.030 inches.
but in my opinion, It's always best to consult the owner's manual or contact the manufacturer for the most accurate and up-to-date information regarding the proper spark plug gap for your specific pressure washer model.
good luck
What gas does a Homelite 16 " Ranger chain saw use
The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle engine oil, and the manufacturer recommends the use of a two-cycle oil that contains fuel stabilizer to keep the mixture fresh if you are not using it immediately.
Where is the spark arrestor on homelite 26bp leaf blower
The spark arrestor screen sits inside the muffler on a gas-powered leaf blower. These screens help prevent heated gases from escaping the internal combustion engines.
https://www.ehow.com/info_8446641_important-arrestor-screen-leaf-blower.html
