20 Most Recent
Greenworks 1600 PSI 1.3 GPM Electric Pressure Washer 51152 Questions & Answers
Electric Pressure washer hums but does not work.
guess is that someone started it without water...and seized the piston. You can try spraying silicon spray into the water intake (lots of it) and then see if that frees the piston. You can start it for a moment without water after spraying silicon into the intake. The alternate ( not recommented) is to open the pump housing and spraying directly into the piston to free it up.... Good luck.
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
50 minutes ago
The Casino I work at
Reprogramming the Chipper Champ 2 chip sorting machine after the programming has been lost can be a bit tricky without access to the specific manual or instructions for that particular machine. However, I can provide some general guidance on how you might approach the reprogramming process:
1. **Consult the Manual**: The first step should always be to consult the manual or documentation provided by the manufacturer for the Chipper Champ 2 machine. The manual typically contains detailed instructions on how to program and operate the machine. If you don't have a physical copy of the manual, you may be able to find it online on the manufacturer's website or by contacting their customer support.
2. **Factory Reset**: Many electronic devices, including chip sorting machines, have a factory reset option that allows you to restore the device to its original settings. Look for a factory reset procedure in the manual or try pressing a combination of buttons on the machine to initiate the reset process. Keep in mind that a factory reset will erase all existing programming and settings, so use this option with caution.
3. **Button Combinations**: If the factory reset option is not available or doesn't work, you may need to reprogram the machine manually using button combinations or sequences. This typically involves pressing specific buttons in a certain order to access different programming menus and settings. Without specific instructions for the Chipper Champ 2 machine, this process may require some trial and error.
4. **Contact Manufacturer Support**: If you're still having trouble reprogramming the machine, consider reaching out to the manufacturer's customer support for assistance. They may be able to provide you with step-by-step instructions or walk you through the reprogramming process over the phone or via email.
5. **Training or Service Technician**: If none of the above methods work or if you're not comfortable attempting to reprogram the machine yourself, consider requesting training from the manufacturer or hiring a service technician to assist you. They can ensure that the machine is programmed correctly and provide guidance on its operation.
Remember to exercise caution when attempting to reprogram or reset electronic devices, especially those used in a professional setting like a casino. Making incorrect changes to the programming could lead to errors or malfunctions in the machine's operation. If you're unsure about any steps, it's best to seek assistance from someone with experience or expertise in handling the specific machine.
4/23/2024 10:04:43 AM •
Garden
Answered
9 hours ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
2 days ago
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
