20 Most Recent
Weed Eater Fl1500 Le Leaf Blowers Questions & Answers
Carburetor adjustment procedure
low and hi speed mixture screws
one adjusts for proper idle
one adjusts for proper high rpm operation
turn them in or out to get the best throttle response and proper wide open throttle rpm's
My Weed Eater FL1500LE gas leaf blower will not
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching! I’m happy to assist further over the phone at
https://www.6ya.com/expert/layne_0fccff498c319c32
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
on Mar 18, 2024
Where can I find a baumr-ag sx45 0.325 chainsaw cog
usually doing a bit of research on google con bring you up a parts list & suppliers. with the make and model number & then type in either service manual or parts list.pdf. of even a schematic can bring you pictures or websites to help. maybe some scrolling through is needed but you should be in the ball park with this one.
3/15/2024 11:12:06 AM •
Garden
Answered
on Mar 15, 2024
I would like to print out a service and parts manual for a 2015 ck30
Obtaining a service and parts manual for a specific model, such as the 2015 CK30, typically involves contacting the manufacturer or an authorized dealer. In this case, CK30 likely refers to a compact tractor model, and the manufacturer would be KIOTI.
3/9/2024 2:05:09 PM •
Garden
Answered
on Mar 09, 2024
Are the cushions on my outdoor sofa waterproof?
Cushion covers are treated with a water repellant coating. Spilledliquids can be easily wiped off. I would recommend removing andstoring the cushions in a dry place when not in use
3/6/2024 9:46:54 AM •
Garden
Answered
on Mar 06, 2024
