20 Most Recent Sharp 30" Built-in Trim Kit for R530BS and R530ES RK51S30 Questions & Answers
There is an electrical short. I recommend you do not try to Start it again, it can cause a fire.
If it is out of Warranty, buy a new microwave
If it is still in Warranty immediately have it repaired
by a qualified company serviceperson
Sharp 30"... | Answered on Feb 04, 2019
I searched using https://www.google.com but did not locate an instruction manual for that model Sharp microwave oven.
Recipe at the link below suggests adding extra sugar before baking.
https://www.allrecipes.com/recipe/140772/easy-microwave-chocolate-cake/?_ga=2.211667349.160497590.1579435247-959462057.1579435247
Sharp Microwave... | Answered 3 days ago
You can try and unplug it for 5 minutes, push the on button to make sure it's completely discharged. Then plug it in. If it does the same thing, it's toast. Getting it repaired will cost about the same as a new one on sale.
Sharp Microwave... | Answered on Jan 11, 2020
GO BUY A NEW UNIT YOU WILL NOT FIND PARTS FOR A 39 YEAR OLD MICROWAVE
Sharp Microwave... | Answered on Nov 21, 2019
if the display does light up but it wont turn on,
Broken door switch, broken in the Open position.
But if there is no display at all (no clock, for example) then look at the power supply chain (including the fuse)
Sharp Microwave... | Answered on Nov 13, 2019
Something must have spilled into the mechanism and dried there. You'll need to access and clean it out.
Sharp Microwave... | Answered on Oct 26, 2019
Download pdf manual https://elektrotanya.com/sharp_r-8460_r-8560_sm.pdf/download.html
Sharp Microwave... | Answered on Sep 20, 2019
Hi Timothy, your Microwave Sharp Half Pint, does not have any receptacle for batteries, therefore, if unplugged, it cannot generate any sound
As Robert Oliver suggests, notice that another device nearby, that if it has batteries, may be making that sound
I hope you find the origin of the beeper
Greetings Franco Dosil
Hola Timothy, tu Microondas Sharp Half Pint, no posee ning?n recept?culo para bater?as, por lo tanto, si esta desenchufado, no puede generar ning?n sonido
Como te sugiere Robert Oliver, f?jate que otro aparato pr?ximo, que si tenga bater?as, pueda estar haciendo ese sonido
Espero que encuentres el origen del emisor de pitidos
Saludos Franco Dosil
Sharp Microwave... | Answered on Sep 17, 2019
You should check for 3 volts on sec coil supply for magnetron but do this check with the hv capacitor and hvr disconnected if 3volts is present , most probably your magnetron is deffective, replace it with the same type
Sharp Microwave... | Answered on Sep 16, 2019
Clean the temperature sensor in the cavity.
Sharp Microwave... | Answered on Aug 28, 2019
Sounds like a door latch needs an adjustment that only a qualified technician can perform for safety reasons.
Try unplugging uni t for 10 seconds,then plug back in. If that doesn't work, contact a technician. For service.
Check your users manual for installation instructions. then reverse engineer them.
Sharp 30" Built-in Trim Kit for R530BS and R530ES RK51S30 Logo
1 questions posted
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
r530bs microwaved keep blowing its fuse
  • Microwave Ovens
