Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
If your Whirlpool upright freezer is working fine but an intermittent alarm is sounding that is different from the high temperature alarm, it could indicate an issue with the door or the door switch. The alarm is designed to alert you if the door has been left open for an extended period or if the door switch is malfunctioning. Check the door seal to ensure it is tight and the door is closing properly. You can also try cleaning the door switch to see if that resolves the issue. If the problem persists, it may be necessary to contact a professional for further assistance.
There shouldn't be any 'jingly tone' at the end of every compressor cycle. You could be hearing something else making a sound after the compressor stops.
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
The solenoids that operate the ice maker and the water dispenser in the door may be getting water internally. I would put a pressure regulator on the line of the pressure exceeds 30 PSI.
All cooling/heating appliances must have a functioning device to control the rise and fall of temperature. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
The freezer is where the cold air is generated. It knows that is not logical to turn off the fresh food side so it determines that it needs the cold from the freezer side, so it over rides the error and will attempt to start. Turn your freezer on to a mid way setting ans give it a few hours to comply. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
