20 Most Recent
Metalfrio Vb12r Display Cooler Vb12r Refrigerated Display Cases Questions & Answers
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
I have a Traulsen 31300 6 half door freezer that cools down to 28F but won't go below.
If your Traulsen 31300 freezer is cooling down to 28°F but not going below that temperature, and the compressor runs continuously except during the defrost cycle, there are a few tests you can perform to help diagnose the issue before considering replacing the expansion valve. Here are some steps to follow:
1. Check Airflow: Ensure that the airflow inside the freezer is not obstructed by any items or ice buildup. Verify that the evaporator coil is clean and not blocked. Poor airflow can lead to inadequate cooling.
2. Temperature Control Setting: Confirm that the temperature control setting on the freezer is correctly set to the desired temperature. Make sure it is not accidentally set too high or too low.
3. Condenser Coil Cleaning: Clean the condenser coils located either at the back or underneath the unit. Dust and debris accumulation on the coils can reduce cooling efficiency. Use a soft brush or vacuum cleaner to remove any dirt or debris.
4. Condenser Fan Operation: Check if the condenser fan is running properly. The condenser fan helps dissipate heat from the system. Ensure it is spinning freely and not obstructed. If it's not working, it may need to be replaced.
5. Check for Refrigerant Leaks: Perform a thorough inspection of the refrigerant lines and connections for any signs of leaks, such as oil spots, bubbles, or hissing sounds. If a refrigerant leak is suspected, it could be affecting the cooling performance, and repairing the leak and recharging the system may be necessary.
6. Pressure and Temperature Readings: To determine if the expansion valve is the culprit, you may need to take pressure and temperature readings at different points in the refrigeration system using specialized equipment. These readings can help identify any irregularities or inefficiencies in the system.
7. Consult with a Professional: If you're unsure about performing these tests or interpreting the results, it is recommended to seek assistance from a professional refrigeration technician. They will have the expertise and necessary tools to accurately diagnose the issue and provide appropriate solutions.
By conducting these tests and inspections, you can gather more information to make an informed decision about replacing the expansion valve or pursuing other potential causes for the inadequate cooling.
6/21/2023 2:35:28 PM •
Freezers
Answered
on Jun 21, 2023
I’m trying to get hold of a manual for a KYOTO (IcelandLtd) Delux KU72 upright freezer. Help would be appreciated...
Unfortunately, I was unable to find a direct link to a manual for the KYOTO (Iceland Ltd) Delux KU72 upright freezer. However, there are a few options that you can try:
- Contact the manufacturer: You can try contacting KYOTO (Iceland Ltd) directly and requesting a copy of the manual. You can find their contact information on their website or through a quick online search.
- Search online: You can try searching online for a manual using the model number or product name. Sometimes, other users may have uploaded a copy of the manual online or posted a link to it on a forum.
- Check for similar models: If you are unable to find the manual for the exact model, you can try looking for a manual for a similar model made by the same manufacturer. The manual for a similar model may contain similar instructions and specifications that can be helpful.
I hope these suggestions help you find the manual you are looking for.
2/26/2023 12:11:34 PM •
Freezers
Answered
on Feb 26, 2023
