http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashxThe timer is used to power a low-voltage sprinkler solenoid valve.
A solenoid is an electrical switch that opens and closes a gas line or water line.
The yellow wires go to your sprinkler system solenoid valve.
The solenoid is the valve that turns water on-and-off.
The 120Volt electric cable that runs the timer connects to the Line and Neutral terminals.
Black to Line terminal, white to neutral terminal
The clock repeats each 24 hours.
Lift and rotate dial until current time lines up with silver pointer
The skipper wheel has pins >> press pin down for each day you do not want watering
Rotate skipper wheel counterclockwise until current day lines up with 14 arrow
Put tripper pins on yellow dial
Each pin represents 12 minutes of watering
To water for 48 minutes, put in 4 consecutive pins
Put pins on wheel at the time you want watering to take place.
To water twice a day, put pins at two different times, and do not put any pins between those times.
