20 Most Recent
Magic Bullet Nutribullet Blender Questions & Answers
NUTRIBULLET BLADES DONT TURN
Sounds like the extractor bearings may be seizing due to rust.
This YouTube vide should help see if it’s the same thing and how to fix it!
Good luck
https://youtu.be/Iw6VXRSHyNM
Used the Nutri Bullet to make 5-6 smoothies. I
If the blades do not turn and you notice hot base hot or a burning smell, unplug the power base and let it cool for an hour. The powerbase will reset once the unit is unplugged.
They recommend not running for more that 1 minute bursts.
strawberry/banana num num !!!
I want to find blender parts in Adelaide Australia
blender parts in Australia are virtually non existent
it is cheaper to junk it and get a better model
the trouble with blenders under 1000 watts is that the motor is not good enough and they burn out ( two for the price of one is the clue to reliability)
it it is fairly new and still in warranty get it replaced
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Motor won't run
Go to the manufacturer website and maybe you can have or get warranty repair. It could also still be under warranty.
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
