Toilet water has leaked downstairs
Hello, W/D here.
Bummer! It will have to be dried out in order to give it another chance at life. I have had very good luck using a hair dryer and a cardboard box. With electronics, they need to be perfectly dry; moist won't do. You can accelerate the process somewhat by using the hair dryer with the
projector out of the box, and drying through the vents, moving the hair
dryer around, getting it as dry as you can. The box method is just to
get the remnants of water and moisture that you cannot see to dry.If at all possible, place a cardboard box around it, or take it down and place in a box. Cut a hole in the sidewall of the box, a little above the bottom of the box, and place the barrel of the dryer in the hole and not impinging on the projector. Cut a similar hole on the upper, opposite side of the box (catty-cornered) for the warm, moist air to escape. Start the dryer on medium (not hot) heat and warm the projector up. Do not leave the process unattended, for obvious reasons. Check the vent for warm air escaping, and look in on the projector from time to time to make sure that the heat isn't causing any harm to the case. You don't want the heat too high, or blowing directly on the projector.
Best regards, --W/D--
