20 Most Recent
Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White Questions & Answers
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
How do you change the heating element
Good Afternoon Friend,
I understand you want to know how to change the heating element in your laundry center, model# FFLE2022MW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician, for further assistance. They have been trained on you appliance and should be able to change the heating element with ease. Hope this is helpful.
-Best Regards-
WP
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand. The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators,
usually ceramic. As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.Replacing one is fairly simple.
- The first thing that you should do is unplug your dryer.
- Once unplugged, remove the exhaust duct.
- Use a screwdriver to remove the electric access panel in at the rear of the dryer.
- Locate and remove the heating element.
- Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
- Replace part if necessary. Elements will usually run $20 or so.
- Assemble in reverse order and test.
This website has some really great detailed step by step instructions on
replacing a heater element. Good luck.
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
