20 Most Recent
Soleus Air DP2-70-03 aka SG-DEH-70-2 Energy Star 70 Pints Portable Questions & Answers
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
I have a D70E A Soleus Dehumidifier that has begun making a rattling noise.
If it’s the one like move, vibration comes from the pump that takes reservoir water to be evaporated. Mine never seems to shut off and is noisy because there’s no water. And eventually it throws an e4 error saying that some water store is full. I can hear compressor come on nicely and quietly. I’ve cleaned the float switch area that was filthy. I was unable to easily remove and fully clean the inside of the donuts. Perhaps the funk is interfering with the float switch. Next step is to research these float switches for how they work. There in another float switch that is not connected anywhere, nor is there a place that it could connect to.
5/10/2020 6:51:11 PM •
Soleus...
Answered
on May 10, 2020
What does E5 mean on Soleus Air dehumidifier?
hi Randal.
this is all i could find on the internet.
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner
problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer.
you could try this link as well to see if its of any help to you.
What does E5 mean on Soleus Air dehumidifier Google Search
12/3/2017 5:22:27 PM •
Soleus...
Answered
on Dec 03, 2017
