20 Most Recent Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Questions & Answers
Picture in directions does not match the part in the kit.
Go to danco web site for correct instructions.
7/28/2017 7:41:44 AM • Danco 89448A... • Answered on Jul 28, 2017
The handle base has a small tab that the handle
Not sure I understand your problem; your handle may be incorrectly installed.
Danco's instructions for replacing this toilet handle can be found here.
1/30/2014 3:39:14 AM • Danco 89448A... • Answered on Jan 30, 2014
Does it matter if the
Sorry to read about your problem, I hope this helps you out.
Nope just the metals will last longer
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
12/29/2010 5:10:24 PM • Danco 89448A... • Answered on Dec 29, 2010
Danco Universal tank lever - 89450A we have
Readjust the chain or lifting mechanism associated with the flapper to lever connection.
11/26/2010 9:48:04 PM • Danco 89448A... • Answered on Nov 26, 2010
I cannot get toilet to
You need to hook the chain shorter going to the flapper...the chain is too long...
heatman101
9/4/2010 10:19:09 PM • Danco 89448A... • Answered on Sep 04, 2010
Does the rubber gasket go inside or outside the
It goes on from the inside.
4/21/2010 2:50:48 PM • Danco 89448A... • Answered on Apr 21, 2010
After flushing it will sound like it is filling up
lower the float a small amount...make sure flapper is closing completely
11/17/2009 1:34:05 AM • Danco 89448A... • Answered on Nov 17, 2009
The toilet sometimes will continue to run after flushing
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
8/26/2009 4:25:32 AM • Danco 89448A... • Answered on Aug 26, 2009
Once installed according to directions, i can't get it to work pr
There is two different types of handles. You have a front mount and a side mount. It sounds as though you might have bought one that is for a front mount instead. Also some toilets are brand specific and you are forced to buy OEM parts instead of generic ones. If the handle is metal you could try bending it to get the "swing" you need. But if you do that, you won't be able to take it back for a refund if it doesn't work. Good luck
4/2/2009 2:23:49 AM • Danco 89448A... • Answered on Apr 02, 2009
2answers
How to reverse direction of shower stem it is a danco 9h-8h and i need to use it on right hand hot side of shower?
Most of those have a quarter turn plastic pie section at the top of the stem. It reverses for right or left (cold or hot) faucets. Turn off the water supplies, remove the top of the faucet and handles, put the pie shaped sections on opposite sides, reinstall the handles and turn the water supplies back on.
9/9/2021 12:35:02 AM • Danco Home • Answered on Sep 09, 2021
I cannot screw the shower spout all the way to the back so it's to the wall> There is a gap. Moen and replacing with a Danco universal shower spout. The copper pipe i think is too long?
Each manufacturer has a different size shower spout. As long as the fitting doesn't leak, put a flange up against the wall and if needed, use calking to fill the space. This is an aesthetic issue only.
10/1/2019 3:52:41 PM • Danco Home • Answered on Oct 01, 2019
Installing a danco large acrylic diverter handle
Is this a question?
5/23/2019 4:19:49 PM • Danco Home • Answered on May 23, 2019
I have a rebuild kit
The issue might be the tub diverter spout. Most such do not seal well. It is a matter of jiggling the spout knob. It should seal better with a little experimenting.
9/4/2017 6:38:14 PM • Danco Home • Answered on Sep 04, 2017
0answers
Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Logo
12 questions posted
Top Danco Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danco Home Expert? Answer questions, earn points and help others
View Most Popular
Danco Home
  • Danco Home
Most Popular Question
after flushing will sound like filling
  • Home
