20 Most Recent
Omega Seamaster 300M Mid-Sz 2551.80.00 Wrist Watch Questions & Answers
The use of helium valve
The Helium valve is beyond the needs of 99% of owners. It is intended to release excess pressure built up at depth on accelerated rise the pressure doesn't equalise quickly enough. Normal ascent from depth needs no intervention.
My OMEAGA 1337 seamaster running
If you open the back lid ...you may be lucky and it may have a balance adjustment ...(manually ) ..It looks like a little lever that can be moved left and right to set the "speed"..and this way adjust it ...left for to slow down ..and right for to go faster when it leaves behind..Most watches have it ..specially mechanical ones..If it does not ,,Im not sure what you can do ..(if it is just electrical ..)
The adjustment Im talking about it is actually the hair-spring tension ...
and it might have something similar even if it is electronic based ..(usually some screws need to be tight or loose and has indications inside ) (numbers)
For about a month, while
Your watch is fitted with EOL (end of life). This does not mean end of watch life, but end of battery life. Replace battery and watch will work as it should.
Rate me, please.
Dear Sir, I have one of the above Omega Seamasters
Hi dunphysteven
It is not normal that the bracelet falls so often.
There seems to be an issue with the product. However the warranty period in most cases is limited to 2-3 years, which unfortunately has crossed in your case.
Therefore in this case u need to pay for the bracelet.
Alternatively you can sell your watch on ebay or some other similar site with the mention that bracelet is an issue.
Hope this helps you.
Regards
TDCL
Had battery changed at 3:00pm watched stopped
The battery was low to begin with, or the electronic timing module has developed a flaw. I recommend going back to the same jewelers and have them change the battery again, if it works they can not charge you.
I have a quartz Seamaster
Time zone and correcting the date: pull the crown out to position 2.Turn the crown forwards or backwards, the hour hand moves forwards or backwards in one-hour jumps. The date can be moved forwards or backwards by moving the hour hand past midnight accordingly.Push the crown back to position 1.
Please click on this
link for the manual. If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
What time of the morning
The date change is a mechanical operation.A gear train turns and rotates a date ring.This turn over is designed to take place at 12 but the wheels can take some time to flip the date over so by 12.30.If its say 3am then the date ring can be re set to make it closer to 12.
For this you will need a good watchmaker look at
www.rolexrepairs.co.uk there is a postal repair service with a free estimate.
Regards
Can i change my watche ?
it is still under warranty
contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
