20 Most Recent
American Standard Williamsburg Toilet Seat & Cover Questions & Answers
I seems that the williamsburg 5395.700.20 toilet
If it doesn't embarrass you, you could take the two nuts off the bolts holding the seat on, put the seat in a bag and take it to a Home Depot or Lowes or Walmart etc and match a new one to your old one. Good Luck
11/15/2013 10:58:29 PM •
American...
Answered
on Nov 15, 2013
I have a fluidmaster ballcock valve that sometime
Well, something is amuck with the valve. What you do is jsut replace it. The plastic gets brittle, eventually.
There is also a chance that the shut off valve washer is causing issues. If the problem persists, look into that, also. The washer sometimes shrinks and will not remain open. It is an easy replacement fix.
5/9/2011 4:22:59 PM •
American...
Answered
on May 09, 2011
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
