20 Most Recent
Sharp LC-60LE600U 60" LCD LED TV 1080P Questions & Answers
Remove black line appears on your LCD TV
You may get a vertical black line appeared on your LD screen. Don't panic. You may not have to replace the LCD panel (cost $1K more) or replace the TV. This is likely due to the issue with X-Y control board (either with connector or electronics). Here is the trick, use your hand to apply pressure on the TV frame (the edge if there is one, not directly on the LCD itself) exactly above or below where the line is. I was able to make the line disappeared in a few trials. I have done this 2 to 3 times in the last 3 years. I guess the same may apply to a horizonal black line and you press on the left and the right of where the line is. Good luck and let us know if it works for you.
This tip may work on 1 line of defect. If you have more lines as group or they appear in several areas, you will have a real problem that needs serious repair.
LC-60LE600U sharp tv will not turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/20/2017 3:16:21 PM •
Sharp...
Answered
on May 20, 2017
Sharp aquos TV is not working after power surge, how do I fix this?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
9/22/2015 2:55:07 PM •
Sharp...
Answered
on Sep 22, 2015
