20 Most Recent American Standard 2748.328 Town Square 5' x 42" Air Bath Tub in White Questions & Answers
Sounds like a septic back-up...if indeed you have a septic tank. This could happen very easily--just from flushing a tampon or cigarette ****. Also certain types of trees have a rapidly growing root system that does nothing but head for the nearest water source, growing and entwining into a septic tank, clogging it up.
If this is the case, call a plumber to get it unclogged, then get some root kill and enzymes to flush down the toilet every couple of months.
American... | Answered on Aug 27, 2010
sounds like the circuit board in your system is faulty
American... | Answered on Nov 15, 2009
Air bath tubs have a preset time limit. it could be that it reached that limit. Especially if the lights are still lit up on the control.
American... | Answered on Feb 24, 2009
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
American... | Answered on Dec 16, 2008
sometimes theres caps on top pop the cap and tighten the screws and sometimes there are nut or wing nuts on the bottom...simple enough for you?
American... | Answered on Sep 06, 2019
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American... | Answered on Jul 12, 2019
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet.
Then....visit this link:
https://www.americanstandard-us.com/parts-support/faqs/toilets
Good Luck!
American... | Answered on May 06, 2019
More likely the sensor has malfunctioned.
American... | Answered on Nov 24, 2018
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
American... | Answered on Nov 12, 2018
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
American... | Answered on Nov 04, 2018
  • Flapper at bottom not sealing correctly
  • Defective fill valve
American... | Answered on Aug 29, 2018
American Standard 2748.328 Town Square 5' x 42" Air Bath Tub in White Logo
4 questions posted
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
american standard 2748 428wc linen town
  • Home
