20 Most Recent Haier HTR-D11 Remote Control TV-5620-120 Questions & Answers
Haier htr-d11 codes
0038,0031,0033,0036. Try these codes. For more information http://electrohelponline.blogspot.com/
11/20/2013 1:25:57 PM • Haier HTR-D11... • Answered on Nov 20, 2013
How can I get the TV to power on?
Try reset TV using instructions given on page 13 of manual.See troubleshooting section on page 16.User manual Haier L42B1180 (English - 19 pages)See page 43 of service manual (roubleshooting)https://www.manualslib.com/manual/1065697/Haier-L42b1180.html?page=44#manual
1/22/2024 7:50:18 PM • Haier Televison... • Answered on Jan 22, 2024
2answers
I have Haier tv model no-LE32K6500AG is showing that please wait for the system to start but it isn't working
One of the most common issues is that the circuit breaker or power breaker of your TV might be faulty. You can check if they are working fine for this issue. There can be simple causes of this problem too such as the plug or remote control defects. If the above solutions do not work, you can try contacting Haier's service hotline and book an appointment to check your TV Sorry.
10/22/2023 3:55:04 PM • Haier Televison... • Answered on Oct 22, 2023
My Haier tv model LE55B1381 has an intermittent problem. It stops working i.e. power is ON but no sound or images. After an hour, it resumes working for a day then stops again.
Hi, please remove all accessories from your tv and monitor it to see if it runs into it's glitches again. Please also remember if you purchase a new remote when this issue started happening or did you start using direct tv ? You can also run a power cycle on the tv if this issue occurs again. Thank you.
11/23/2022 3:13:04 AM • Haier Televison... • Answered on Nov 23, 2022
2answers
How can I rotate the screen of my haier tv model LE32B7000
You should enter its service mode menu to do that. Visit these sites by a desktop computer and type in the model number of your set at the search window at the right side of the site to reach it very fast. Mobile view have no search box. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/
9/26/2022 5:05:59 PM • Haier Televison... • Answered on Sep 26, 2022
2answers
Haier TV has picture and changes channels fine, but the sound has gone. It is NOT that the Mute is on. The TV downstairs is fine so it is NOT the cable company.
You can try unplugging the TV for a bit to see if that resets it. Next check if the TV was set to use external speakers by accident. Finally, try a factory reset. Please add a comment with the model of the Haier TV for directions for checking the audio output menu and factory reset. I hope this helps. Cindy Wells (I had a different TV from a different brand that had no external audio port. It would sometimes lose audio on one channel or several channels. Unplugging the TV solved the problem; the factory reset option in the TV menu didn't resolve the issue.)
9/25/2022 4:33:25 PM • Haier Televison... • Answered on Sep 25, 2022
2answers
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat. The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions. I hope this helps. Please add a comment with the model of your unit for further information. Cindy Wells
8/22/2022 1:04:03 AM • Haier Televison... • Answered on Aug 22, 2022
2answers
Do I need an HDMI cable for my Wii system to work on my Haier tv
Yes you do
7/14/2022 7:13:37 AM • Haier Televison... • Answered on Jul 14, 2022
I have a Haier tv with no remote. It was working fine, I'm located in Baja California and I VTV but I turned it on and it went straight to no signal I need to know what input to put it on.
Normally you need a remote to access the Input Source. All televisions need a remote! If you can access Input, just scroll through them one by one until you get the signal. Replacement remotes are typically $12 to $20. Some Haier as $31. Add your model number after the word 'Haier'. https://www.google.com/search?q=haier+tv+replacement+remote ..
5/25/2022 2:14:51 AM • Haier Televison... • Answered on May 25, 2022
Haier 55E3500 tv has sound, no picture or backlight
Your backlights have failed and need replacing, parts may be hard to find
3/10/2022 6:56:56 PM • Haier Televison... • Answered on Mar 10, 2022
2answers
New remote for haier tv does not work. Removed batteries and pressed every button 30 secs. Put batterirs back in still dors notwork
Remove the batteries of remote control and press the on/off button for 1 minute facing the remote towards tv set. Then put the batteries back and yesss!! It works ??
12/14/2021 7:24:06 PM • Haier Televison... • Answered on Dec 14, 2021
My haier tv shows Run Channel Auto Scan, but remote is not working to set it. What can i do?
If you don't have a remote, Go to the menu where it says run channel auto scan, hover over the run button and .(on the tv) press volume up, volume down, input and menu at the same time. This (depending on your model) should start the scan
10/23/2021 4:38:14 PM • Haier Televison... • Answered on Oct 23, 2021
Haier 65UG6550G. There's power but no display. Someone gave it to me with no remote. Said one day it just stopped working.
Some sets won't power up without a remote control. Just try to buy its original or universal remote control. There is no other way. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search box.
7/13/2021 1:26:04 PM • Haier Televison... • Answered on Jul 13, 2021
Cannot operate Haier TV without remote.Universal will only turn on and off, volume up and down. Cannot stream with Amazon fire stick. Cannot get into menu to change input. What can I do?
1. Obtain a replacement Haier remote control 2. Obtain a URC that handles all Haier functions
12/21/2020 12:27:47 AM • Haier Televison... • Answered on Dec 21, 2020
Necesito los cuatro digitos para un tv haier
The code for your Haier TV would be found in a compatible remote control.
11/8/2020 4:02:54 AM • Haier Televison... • Answered on Nov 08, 2020
I have a Haier TV 55DA5550 It does not turn on sometimes unless you unplug from power for a few minutes
start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks on Samsung TV's usually indicates a bad power supply.
5/14/2020 6:35:59 PM • Haier Televison... • Answered on May 14, 2020
3answers
How do I change the input source on a Haier TV without a remote? My TV is stuck on "composite" mode, n I lost my remote. Please help!
You need the remote to access these functions. You can buy a new one most likely here: www.remotes.com
4/11/2020 2:43:30 PM • Haier Televison... • Answered on Apr 11, 2020
Haier HTR-D11 Remote Control TV-5620-120 Logo
1 questions posted
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
haier htr d11 codes
  • Televison & Video
