20 Most Recent Pulsar Chronograph Watch Questions & Answers
The timer on Pulsar watch does not line up at 12 when reset.
To set the timer hand on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#1), FIRST CLICK (#2) & SECOND CLICK (#3).
First, pull the crown out to the second 'click' position (#3) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #3!)
Push and hold Button "A" for two (2) seconds. The dial will sweep around to the 12 O'clock position. You can advance the timer while the crown is in position #3 (second click out) to reset it back to the default position.
The manual says that if you pull the crown out to position #3 while the timer is measuring, the hand will reset back to the 12 o'clock position... I haven't tried that, so I can't confirm.
3/4/2016 10:09:48 PM • Pulsar... • Answered on Mar 04, 2016
How to set alarm on Pulsar Chronograph 100M
See PDF here to solve this problem.
Wish Pulsar would have included this info with their watches!
http://www.pulsarwatches.com.au/manuals_pdf/121_1.pdf
11/10/2015 5:25:19 PM • Pulsar... • Answered on Nov 10, 2015
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
4/22/2015 2:23:09 AM • Pulsar... • Answered on Apr 22, 2015
0answers
Pulsar manual
Be the first to answer 3/1/2014 3:15:30 AM • Pulsar... • Posted on Mar 01, 2014Be the first to answer
Put new battery in pulsa chronograph 100m watch
You might need a jump start the watch, or cleaning. I usually try using a air dust blower ball to get all the particles that is invisible to the eye, you can do this on the movement and around the battery area. Aftwards try inserting the battery again then pull out the stem and move it clockwise at least 10 times passing the 12'o clock marker. If the watch is not brough back to life you can try one last thing before buying a new movement or taking it to the watch repair shop. If you take it to watch repair shop they might charge you a few bucks to jump start the movement. I hope this helps. Marcelo
10/28/2013 4:07:31 AM • Pulsar... • Answered on Oct 28, 2013
0answers
2answers
I need an instruction guide for a Pulsar N945-6A20
Go to pulsar website look under manuals and select PWF series
7/9/2013 12:03:24 PM • Pulsar... • Answered on Jul 09, 2013
Pulsar Chronograph 100 m -
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
12/23/2012 8:44:00 AM • Pulsar... • Answered on Dec 23, 2012
0answers
0answers
YM62-X159 Pulsar
Be the first to answer 11/21/2012 1:55:43 PM • Pulsar... • Posted on Nov 21, 2012Be the first to answer
Pulsar Chronograph Watch Logo
48 questions posted
Top Pulsar Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
View Most Popular
Pulsar Watches
  • Pulsar Watches
Most Popular Question
instructions start watch pulsar world
  • Watches
