20 Most Recent
Raymond Weil Tango 5560-STP-00328 Wrist Watch Questions & Answers
Hello I need to change
I have a RW one too and to be honest given what I paid for it, I thought it best to take it to a jeweller/ watch repair specialist; peace of mind in case I damaged it myself.
Watch strap for tango clasp where it fastens on to
this is an easy fix that can be done by a quality watch maker o jewelery repair shop , should cost no more than 10-20 dollars. All you need to do is bring it in and tell them that you need to have the clasp riveted. Its just a pin of sorts that has come undone. Look and see if there is a fast fix in your area they are usually very affordable and do the repair as you wait.
http://www.fastfix.com/
I don't know the model number of my wife's Weill
There is a glue used in engineering circles called "threadlock". It is made by Loctite and is used for situations where it is important that screws do mot come out.
I suspect that your jeweler will use this glue but it might be useful to check this,as if he isn't, then you have another option if his try fails.
How successful a glue is will depend on how badly the thread is damaged before the glue was applied. The more glue that is needed to fill the gap between the two threads, the more likely it is to give way.
The best engineering option is to tap a larger hole and use a larger screw, but I doubt whether this is possible with the small scale of watches.
Battery has died were can i go to replace it
Try going to the RW website and finding their list of retailers in your area. Most reputable jewellers who sell high end watches should also be able to do this for you, but be careful if the watch is under warranty as you may have to do it through an authorised service centre.
HI, I HAVE A LADIES RAYMOND WEIL WATCH WITH THE NUMBER 737 ON THE BACK. PURCHAED APPROX 1980S. THANK YOU
Hello -
What do you need help repairing on your watch?
Fixya.com is a website intended for asking and answering questions on how to go about REPAIRING THINGS.
Please click or tap on Comment here and type in the additional information.
Note: If you are hoping for a valuation of your watch, doing valuations is also not within the scope of Fixya. For a valuation, I suggest you take your watch to a well-respected quality jewelry store in your area and ask one of the employees there about how you can have the watch valued. Any such appraisal will come with a fee.
Best wishes.
