20 Most Recent Sharp R-353 Microwave Oven Questions & Answers
I have a sylvania model 11092b. all my functions
I have one that does the same thing and its problem is a bad door switch. When I took the case off, the switch looked melted. It was made in 2008 also.
7/17/2017 3:05:56 PM • Sharp R-353... • Answered on Jul 17, 2017
Replaced fuse still not working
see this causes and fix it. God bless youNo Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.Test too c.breaker and reset+power cord+transformer+capacitor+rectifier HV+Magnetron for open , or faulty. see the diagrams9_25_2012_3_47_20_pm.jpg9_25_2012_3_47_37_pm.gif9_25_2012_3_54_54_pm.jpg
9/25/2012 3:55:00 PM • Sharp R-353... • Answered on Sep 25, 2012
0answers
Sylvania Microwave oven SC-11100 We have one of
Had a power outage when the unit was hooked up power came back on now unit is beeping like morris code, how do i clear or reset.
8/15/2011 6:05:00 PM • Sharp R-353... • Answered on Aug 15, 2011
Display has stopped working. All
There is a fuse located inside the unit. This takes special tools to get inside due to high voltage. I recommend calling a tech out to repair a microwave.
Consumer Product Safety Commission Electrocution Hazard with Do-It-Yourself Repairs of Microwave OvensCPSC Document #5061
The U. S. Consumer Product Safety Commission (CPSC) warns against do-it-yourself repairs of microwave ovens. Each year, on average, four people die from electrocution trying to repair their microwave ovens. Microwave ovens use high voltage which makes it particularly hazardous for consumers to remove the cover and touch electrical parts. The possibility for electrical shock from a microwave oven still exists even after the oven is disconnected from the power source. Should certain internal devices fail, even unplugged ovens can cause serious injury.
The Commission strongly recommends that consumers have professionals repair microwave ovens because electrical appliances can be hazardous if consumers expose live electrical parts.
/!\ WARNING
ELECTROCUTION HAZARD
HIGH VOLTAGE
Removing the cover of your microwave oven and touching an electrical part can kill you.
Have a professional repair your microwave oven it may save you some time.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
5/20/2011 1:44:56 AM • Sharp R-353... • Answered on May 20, 2011
0answers
My Sylvania micro/convec oven was installed in my
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
2/13/2010 1:14:19 PM • Sharp R-353... • Answered on Feb 13, 2010
CANT START MY SYLVANIA MICROWAVE MOD P70D20AL-D5
Yeah,same old American name on a foreign product. Even try to find a representative in the USA? Seems this is caused by the connector on the timer board. The cable connection is to blame. Too much heat and humidity on the connector.
12/10/2009 11:36:30 PM • Sharp R-353... • Answered on Dec 10, 2009
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
10/28/2009 12:57:41 PM • Sharp R-353... • Answered on Oct 28, 2009
Beeping will not stop and problem starting microwave
The board has malfunctioned . replace it
9/17/2009 6:27:39 AM • Sharp R-353... • Answered on Sep 17, 2009
Second oven with the same problem
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The best place to order Sharp parts is Tritronics.
1/2/2009 8:54:43 PM • Sharp R-353... • Answered on Jan 02, 2009
MANUAL WANTED TO DOWNLOAD
Check out the manual download section at www.sharp-usa.com
6/30/2008 3:55:12 AM • Sharp R-353... • Answered on Jun 30, 2008
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
6/22/2008 10:28:19 AM • Sharp R-353... • Answered on Jun 22, 2008
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
3/16/2024 5:08:07 PM • Sharp Microwave... • Answered on Mar 16, 2024
Sharp carousel convection microwave model r9h10 user manual
I can send you the instruction manual for Sharp R-9H10. Please send your mail [email protected] is mine
1/19/2024 2:42:43 AM • Sharp Microwave... • Answered on Jan 19, 2024
Cannot reset Sharp R-4A52 Microwave, display keeps flashing.
Turn the microwave oven to the "On" position press "Stop/Clear" a few times -- the microwave should return to normal mode.
12/17/2023 2:58:27 PM • Sharp Microwave... • Answered on Dec 17, 2023
Sharp R-353 Microwave Oven Logo
Popular Tags
20 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
replaced fuse still not working
  • Microwave Ovens
