20 Most Recent
SK Paslode Sk312 Framing Nailer O`ring Parts Kit Questions & Answers
Jammed
Make sure that you are using the correct angle nails and head type,,,some use clipped head , others full head,,,others offset full head
Paslode compact nail. the firing pin will not
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
Central Pneumatic item 94000 nailer.
Parts for central pneumatic guns are /should be available from Harbor Freight.com. Call their 800 number for information. If no joy, take your parts to Dewalt service center to try to match parts with Porter Cable framer. Porter cable parts are very close match to your gun. Good luck
Paslode framing gun will only
Problems with safety foot/ trigger will prevent gun from firing. Simple test, to discover issue. Remove nails for safety, remove trigger and dry fire gun by directly pressing trigger pin in various positions. If gun fires as needed, examine safety foot /trigger for parts needing adjustment / replacement. Second test, remove nails and disconnect air. Move gun from upright position to upside down and listen for movement of parts within gun. If you hear or feel parts moving inside of gun, orings are too loose. Parts inside of gun should not move and be well lubed with silicone paste (sold at lowes in the plumbing dept. used for faucet orings). Good luck.
I was given a Paslode Sk312 so what type and size
The nail gun you mention was put on the market in 1973 and it is very limited. It can only handle a few different nails without retooling. That means, you will have to have it modified to work with nails other than what it was originally designed for.
Warning ligt flashing
please check your model number , the paslode sk312 does not have a warning light since its a air powered gun
I have a Central Pneumatic air nailer that has the
You can call Harbor Freight and see if they have the repair kit available. 1-800-444-3353. Sometimes they change the models and will not have parts available. It may take up to 6 weeks for you to get your parts if they are available. Be prepared to wait. The parts will not be expensive. Depending on which seal you are talking about, you may have to order an assembly. I am directly talking about the trigger seal. This part seems to crumble the most. If you require more information please post additional information about your model and the seals you are requiring.
