High voltage circuit number two has a defective connection or component.
The service manual is here: http://www.microwavedisplay.com/R22GV_R22GT_R23GT_R24GT_sm.pdf You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
The R-23GT and the R-24GT have been preset for 230V operation.
If you need to change this oven for 208V operation, follow instructions below.
1. Unplug oven. 2. Remove one screw(A) from the Voltage Select Cover located on back of the oven near the bottom. 3. Remove the Voltage Select Cover and rotate 180 degrees. 4. Reinstall the Voltage Select Cover using one screw(A) removed in Step 2. 5. Plug power cord into wall outlet.
Your oven is now ready for 208V, 60Hz operation.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
I hope you didn't run the microwave with nothing in the cavity, if you did, it will damage the magnetron.
The turntable dishes do get hot depending on the quality of the glass used to make it. Heat is caused by impurities in the glass.
If you run it with no food in the oven, the glass will try to absorb the energy with atastrophic results usually.
