20 Most Recent
Kohler K-4709-96 C3-200 elongated toilet seat with bidet functionality and Questions & Answers
I have to replace the 81100 in my Kohler toilet
all parts are replacable in any toilet, don;t know the number you have on here but am assuming it's the douglas valve the center valve that has the hose going into it,,, if this is it call kohler and they will send you the part, you may have to remofve the tank wich there are 3 bolts that hold the tank to the bowl,,,,,
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
