20 Most Recent HP ProBook 4540s Notebook PC ENERGY STAR Questions & Answers
How to increase the volume of hp probook,4540s
push volume up key.?
6/25/2021 12:13:19 PM • HP ProBook 4540s... • Answered on Jun 25, 2021
HP probook 4540s plugged in not charging
Simply unplug the power from the adapter, leave for some minutes then reconnect.
7/4/2014 6:55:13 AM • HP ProBook 4540s... • Answered on Jul 04, 2014
0answers
Probook adapter plugged in but not charging
it might be two reason 1-due to overheating and if u format ur lappy and install other os then probably this prob occur ,this can be undo by right click on my computer icon and check if all the components are working or not if there are small triangles formed then this are not installed and u have to install them through net or recovery is best. 2- the charger id burnt out due to low or high voltages fluctuations.in this situation u have to buy a new charger or repair the old one by arun
12/23/2013 10:31:32 AM • HP ProBook 4540s... • Answered on Dec 23, 2013
4answers
Function buttons not working (volume control, brightness, locking, etc.)
Hi,Try using Fn key + the F1-12 buttons.Hope that the issue is that simple, please reply to this: did it or it didn't help.
9/30/2013 4:04:40 PM • HP ProBook 4540s... • Answered on Sep 30, 2013
Hp 450 notebook (ENERGY STAR) f2 and ffff3 button
you can try using the key F. sometimes depend of the adjustment BIOS setup, the key FN can be enable, or dissable. God bless you
9/30/2013 12:30:56 PM • HP ProBook 4540s... • Answered on Sep 30, 2013
0answers
Hp 4540s locking function is not working.how i correct it?
Do you mean the locking function on the screen when you close it?
2/28/2013 1:56:56 AM • HP ProBook 4540s... • Answered on Feb 28, 2013
Blue Screen Error
What were you doing ,just prior to the shut down? Take a look at this:http://pcsupport.about.com/od/fixtheproblem/ht/stoperrors.htm
12/7/2012 2:18:42 PM • HP ProBook 4540s... • Answered on Dec 07, 2012
WiFi not working, cant fine DNS server
on ONE PC or all and TV? answering for ALL PC fail. your router not told read the manual on our unstated router . then using (a it told you) a browser on the PC go to 192.x.y.z address, (it tells you) and set DNS to 1.1.1.1 save exit router service page. see it works./ the router has a name , 15 makers? and zillions of models all are not the same but all have a DNS page, ever one,(for 20 years)
1/19/2022 3:00:59 PM • HP ProBook... • Answered on Jan 19, 2022
How do I remove the BIOS password from an HP Laptop Probook 6450b, that has Ubuntu
The only way I know to reset or clear the password is to know the original one. BIOS passwords are stored in Flash memory and therefore cannot be cleared by removing the CMOS battery like in the good old days.
12/26/2021 2:56:40 PM • HP ProBook... • Answered on Dec 26, 2021
I just bought a used no manual hp probook 6455b laptop & can't figure out how to turn wifi on
I'm assuming your using Windows 10. Look at the keyboard. On the top row of buttons, just above the numbers, there are a series of 'f' number buttons. Check button f12. It should have a small light on it. White means the wifi is turned on, orange means it is turned off. press the button to switch it on and off. The laptop uses the term "Airplane Mode". If this doesn't work you will need to check your WiFi network is listed on the laptop. Go into 'Settings' and go to the 'Network & Internet' settings. Go to the WiFi settings button listed on the left of the screen. You should see your network listed. If you cannot see it listed go to "see available networks" and click your network. It will ask for your security Code to be able to connect.
4/24/2021 12:01:58 PM • HP ProBook... • Answered on Apr 24, 2021
2answers
When power is on shutdown by itself
It sounds as if your laptop is overheating. You need to service the cooling system by clearing any dust and debris from it and also applying fresh thermal paste.
7/5/2018 10:43:52 AM • HP ProBook... • Answered on Jul 05, 2018
Hp probook 4730s all of my USB ports (4) will not work. is there something I can try to fix this?
did you change OS> did change the OS since bought new? no OS stated, why does not one person here say what OS is there.???? its half the system. that. it came new with Linux or windows XP to Windows 8.1 in 32bit and 64bit versions (click control panen, click system) behold the true OS name and version before your eyes. its like saying my FORD died, and no model, gee a Model "A:? here are some facts, most times. dead USB is this. you changed the OS and failed to use the HP driver at HP.com now 1 usb chip works and the other does notl my Elitebook does that, I upgraded to W10 (with zero HP support on purpose) then USB 3 ports went dead, so had to ID the chip its a NEC chip the Intel inside is USB2 only. then the NEC web site had my chip driver. and now those ports work. See how not saying your OS makes help so hard, this is my example. first test the ports only with a test mouse (test all ports now) think small think simple and a mouse is that. does that fail, i can think of 100s of USB devices that will fail hard in w10, all old things why not tell the helper what you plugged in. and be web connected are you.? tell if DM device manager shows any errors at all? did you first use device manager, to see that device fail plugged in? and then right click it and pick update this driver. or did DM shows all USB ports dead.? it just 2 clicks to get there. then it fails, if yes, then MS does not have the driver, we can go to MS right now and prove that. if i get the HARDWARE IDs out of your Device manager page and look in the MS data base i can see if it is supported. case in point old web cams not. old USB wifi dongles not. and more 100s not and 100s yes. that is how it works and goes. now lets got HP.com and look first there, they made it , NOT MS. lets say you said w8.1-64bit OS and i show. https://support.hp.com/us-en/drivers/selfservice/hp-probook-4730s-notebook-pc/5060893 load all the 4 lines of drivers there. there are 3 paths here get the drivers from HP. get them from MS, automatically PnP or manually (ask now manually) get them from the USB chip maker, intel or whomever. if the USB chip really is dead, and the HP driver fails. (I bet not) then get the hardware IDs. tell me that and will fetch them for you easy. its really easy if you know how,and all ways how. if this shows errors , anywhere here, the driver for these chips are wrong.! if you learn how to get the Hardware IDs its 10x more easy. usbnormal-acynybaztzcmm2mvmvzetwcp-4-0.jpg
3/4/2018 1:59:07 PM • HP ProBook... • Answered on Mar 04, 2018
Hp probook 4510 not powering up (orange light flashes a few times when power button is pressed
Disconnect power adapter. Remove the battery hold down power button 10 seconds plug in Power adapter press Power on
9/13/2016 8:44:50 PM • HP ProBook... • Answered on Sep 13, 2016
2answers
HP 4530s BIOS admin password
Here is a post about how to hack hp password with Windows Password Recovery Tool, you need it. Don't waste time at unnecessary help. http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
8/6/2016 9:44:41 AM • HP ProBook... • Answered on Aug 06, 2016
3answers
Block pop ups
In Explorer go to tools, select block pop ups.
3/29/2016 4:26:23 PM • HP ProBook... • Answered on Mar 29, 2016
HP ProBook 4540s Notebook PC ENERGY STAR Logo
24 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProBook HP
  • ProBook HP
Most Popular Question
function buttons not working volume
  • Computers & Internet
