20 Most Recent Noritz 13.2 Gallon Residential Tankless Water Heater - N-132M Questions & Answers
Code 125 on my Noritz tankless water heater
Call noritz(866) 766-7489 http://www.noritz.com/contact-us/Don't buy a tankless water heater. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1/16/2015 7:51:28 PM • Noritz 13.2... • Answered on Jan 16, 2015
How do your flush the heater out. I have a lot of
Question posed under tankless water heater.
1) Utube has videos. Search de-lime tankless water heater
2) Open following links for instruction pdfs:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
3) Open following link for tank-type water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
9/13/2011 11:21:25 PM • Noritz 13.2... • Answered on Sep 13, 2011
Takes 4 minutes for hot water to reach bath room
its normal with long distance on a tankless witout a circulating system to keep constant hot water because the water heater is always off untill u turn on a faucet then it has to heat up the water all the way from the heater to ur faucet thats what conserves energy not running all the time untill u turn it on. U could install a circulating system but now u have that cost and something running again to cost u money to keep hot water where u want it win lose situation
4/28/2011 4:49:42 PM • Noritz 13.2... • Answered on Apr 28, 2011
Receiving a error code 73
Unfortunately this may be a damaged PCB.
This could have happened if you removed the jumper cable whilst the power was on!!
Here is a link to the pdf file I think you have been looking for.
If this does not open,just let me know and I will try something else!!
Andy
http://www.hajocayork.com/files/Noritz_Field_Manual_Old.pdf
2/19/2011 10:24:34 PM • Noritz 13.2... • Answered on Feb 19, 2011
Noritz: Tankless Water Heater. I have an error code 99 on my Noritz tankless. How do l reset it please?
Remove the bird's nest in the flue. The 10, 59, 90 and 99 error codes indicate that a Noritz heater has experienced a combustion abnormality. In most cases, it is the result of an obstruction in the heater's flue. Examine the flue to see if it is blocked by debris and clean if necessary.
How To Resolve The Seven Most Common Noritz Tankless ...
Noritz https://www.noritz.com > Blog Nov 16, 2015 - This error code involves a breakdown in communication between two tankless water heaters using the Quick Connect Cord. It can occur when more ...
Troubleshooting Noritz Tankless Water Heaters and Error Codes
home-water-heater.com https://www.home-water-heater.com > noritz-error-co... Error code 90 and 99 ... Action: Check for the obstructed venting, improper gas burning (flame shape and color change). Ensure the water heater gets the ...
Error Codes for a Noritz Water Heater - Waterheatertimer.org
7/11/2023 4:35:39 AM • Noritz Water... • Answered on Jul 11, 2023
Noritz error code 99
I have a error99 on my tankless how do l reset it?
7/11/2023 3:50:38 AM • Noritz Water... • Answered on Jul 11, 2023
How to clear error code 78 on a noritz tankless
For a Noritz tankless water heater, error number 78 indicates a problem with the fan motor. The instructions below will help you clear the problem number 78 on a Noritz tankless water heater:
  1. Turn off the power to the tankless water heater by either disconnecting it or switching off the circuit breaker.
  2. Verify that the fan motor is clear of any obstructions or debris that may be preventing it from operating properly.
  3. Check the fan motor is receiving power by measuring the voltage across the fan leads with a voltmeter. Verify that the electrical connections to the fan motor are secure if there is no voltage.
  4. If the fan motor is broken or not operating properly, it may need to be replaced. For further assistance with the repair or replacement of the fan motor, you can contact Noritz technical support or a certified HVAC specialist.
  5. After resolving the issue with the fan motor, switch off the power to the tankless water heater for at least 30 seconds before turning it back on. This will clear the error code and restore normal operation to the device.
  6. If you are unclear or uncomfortable with any of these processes, you should seek the aid of a certified HVAC specialist or Noritz technical support.
3/21/2023 2:08:57 PM • Noritz Water... • Answered on Mar 21, 2023
Noritz Tankless Water Heater - Error Code 20 - Priority Light Flashing - EZ98DV
Error Code 20 on a Noritz tankless water heater (model EZ98DV) is typically associated with an issue with the "priority" function, which is a feature that allows the water heater to prioritize certain uses of hot water over others. When the "priority" light is flashing and error code 20 is displayed, it typically means that there is a problem with the priority function and it needs to be reset. To fix this issue, you can try the following steps:
  1. Turn off the power to the water heater by turning off the circuit breaker or removing the fuse.
  2. Wait for about 10 seconds and then turn the power back on.
  3. Press and hold the "priority" button for about 5 seconds, until the "priority" light turns off.
  4. Turn the water heater back on and check to see if the error code has cleared and the "priority" light is no longer flashing.
If the error code 20 still appears and the priority light is flashing, it's best to consult the manual or a professional technician to diagnose the problem. It's important to note that the error code 20 can also be caused by other issues such as, faulty thermistor, faulty thermistor harness, faulty PCB, etc. So, it's best to get it checked by a professional.
1/15/2023 4:59:24 PM • Noritz Water... • Answered on Jan 15, 2023
2answers
Fuse keeps blowing on the circuit unit
Replace the circuit board, or call a technician to do it. No one repairs field replaceable subassemblies any more.
7/16/2022 6:26:38 AM • Noritz Water... • Answered on Jul 16, 2022
Noritz water heater blinks 122 but no hot water
I am having the same error code. Did you ever get an answer?
6/26/2021 10:07:53 PM • Noritz Water... • Answered on Jun 26, 2021
Noritz Tankless Water Heater N-132M code 39
ask Noeitz
4/22/2021 5:41:09 PM • Noritz Water... • Answered on Apr 22, 2021
Error code 903 for a Noritz hot water
I searched for that error number 903 using https://www.google.com and saw several fraudulent sites, so beware. There is a similar error number 90 mentioned several places, but that error requires a technician to repair it as it may be dangerous to do it yourself. Noritz in the United States has a search feature to find a technician if you need one. https://www.noritz.com/home-owners/find-a-servicer/
8/29/2019 1:36:21 PM • Noritz Water... • Answered on Aug 29, 2019
My noritz water heater: error code: 11. It is an N-0931m. Thanks
Code 11 is ignition failure. Ensure that your gas is turned on. Start by checking the vent system to ensure there is no obstruction or separation in the vent system. Second I would recommend flushing the water heater with vinegar or Rectorseal Calci-Free. Calcium and scale build up in tankless water heaters can cause several failures that are not directly related to the specific code displayed on the heater. If the problem persist I would look for a plumber that is familiar with tankless water heaters.
3/2/2019 1:02:59 PM • Noritz Water... • Answered on Mar 02, 2019
NORITZ CB BOILER BURNER NOISE
You should try to describe the noise and what is happening when the noise occurs. Then someone may be able to give you some diagnosis of the problem. For example, does it make a big boom sound went it lights the burners? Then you might need to clean and adjust the pilot light.
12/25/2018 1:52:02 PM • Noritz Water... • Answered on Dec 25, 2018
2answers
What is noritz code 67 and how to fix when it appear?
Here is a link to all the Noritz error codes. There is NO Code 67. https://inspectapedia.com/heat/Noritz-NCC199-Error-Codes.pdf
11/21/2018 7:13:05 PM • Noritz Water... • Answered on Nov 21, 2018
Resolving an error code 51 on Noritz nrc98-dv lp tankless water heater
I need the full model number of the water heater to pull the manual on it for you.... so far only an error code 61 is shown. sometimes a 6 can look like a 5 on a digital display if it's a 6 then error code 61 is bad fan motor or printed circuit board that sends power to the fan motor.Get me the full model number, we can go from there
11/13/2018 1:23:06 AM • Noritz Water... • Answered on Nov 13, 2018
Noritz 13.2 Gallon Residential Tankless Water Heater - N-132M Logo
Popular Tags
5 questions posted
Top Noritz Water Heaters Experts
Paul Carew
john h
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Noritz Water Heaters
Most Popular Question
receiving error code 73
  • Water Heaters
