20 Most Recent
Vanguard International Vanguard 82V66-2T Electric Water Heater Questions & Answers
Flame goes out.
it sounds to me light your thermo coupler is shot if this is replaced it should be o.k., thank you.
1/16/2010 10:44:49 AM •
Vanguard...
Answered
on Jan 16, 2010
No hot water. hitting reset button starts it up but keeps tripping breaker
-Did you buy it directly from Grainger? The model # is actually 82SV30-2T. The "model #" you provided is Grainger's product code.
-Is this a new installation or is this an older water heater?
-Is this wired to a 25 amp breaker. (It should be.)
-Did you re-use existing wire? If so, is it at least #10 copper? (It has to be #10 or larger to comply with code) It isn't copper-clad aluminum or cotton over rubber insulated, right? (It should not be)
-Have you re-wired the heating elements? If so, you need to restore the wiring to the way it was configured from the factory.
Let me know if you need further assistance.
V/R
5/24/2009 4:14:51 PM •
Vanguard...
Answered
on May 24, 2009
We have a vanguard hot water heater, and the inlet and outlet toppings ,bolts, will not unscrew, any suggestions on getting them off?
The pipes coming out of the heater normally do not unscrew so that should not be what you are trying to unscrew. The connections to these pipes do unscrew and a 12" or larger wrench should be able to break the bond on the pipe threads and unscrew. Sometimes it helps to apply some WD-40 or any penetrating oil and then tap on the nuts with a hammer to help break up any corrosion or other bonding material that is holding the nuts.
Go to the manufacturer's website and enter your model number and click on "Support" and there should be a FAQ's, Owners Manual or other support options for you. Otherwise the website may have a "Contact" phone number to call or a way to Chat online.
12/25/2018 2:05:46 PM •
Vanguard...
Answered
on Dec 25, 2018
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
