20 Most Recent Bosch Ariston GL4 GL4 Point-of-Use Electric Mini-Tank Water Heater Questions & Answers
Where is the reset located on a ariston gl4 hot water heater?
It would be on the thermostats.
10/26/2018 2:22:40 PM • Bosch Ariston... • Answered on Oct 26, 2018
Replace the anode?
11/15/2014 10:09:08 PM • Bosch Ariston... • Answered on Nov 15, 2014
No hot water
Get a multimeter and check power first. If you have power going into the water heater, proceded to replaced the heating element. The replacement can only be done by empting the tank and turning the brakers off. Good Luck!
1/13/2014 5:02:53 AM • Bosch Ariston... • Answered on Jan 13, 2014
Water leaking through the power cord hole
Buy new water heater.The tank is rusted out.http://waterheatertimer.org/How-to-install-under-counter-water-heater.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2012 5:10:53 AM • Bosch Ariston... • Answered on Jul 19, 2012
0answers
Bubbling water at pressure releaf valve on top of
Rusted water usually means anode rod depleted and tank is rusting. Change 570241 anode rod every year or so.
Boiling water could mean bad thermostat causing run-away heating so water is released out of TP valve. Replace 994062 thermostat for 4 gallon.
Leaking water at TP valve could mean bad TP valve: replace TP valve with generic valve from hardware store.
Open link for diagram, parts and replacement information
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
6/15/2011 12:01:14 AM • Bosch Ariston... • Answered on Jun 15, 2011
My Ariston 4 gallon water
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
4/2/2011 10:25:00 PM • Bosch Ariston... • Answered on Apr 02, 2011
My gl4 ariston the only way it will heat water is
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
1/14/2011 11:19:44 AM • Bosch Ariston... • Answered on Jan 14, 2011
Installed an ARISTON point of use hot water
After installation check the water temperature. If adjustment is necessary, remove front
cover to adjust thermostat. Clockwise to increase the temperature and
counter clockwise to decrease it.
1. Pry off the round cover plate from its right hand edge with
3. The cover can now be removed by pulling out its left-hand edge.
When reassembling, work in the opposite way being careful to insert the tongue
of the cover into the slot.
1/14/2011 11:11:33 AM • Bosch Ariston... • Answered on Jan 14, 2011
How do you drain the Ariston GL4
is there a pet **** on the bottom under a plastic cap? you might have to take the cover off and I would recomend putting some boiler drains in the line for future draining,, all units of water heaters have drains and looking at the picture I see something sticking down on the bottom see if thats not the drain
6/11/2009 2:44:53 AM • Bosch Ariston... • Answered on Jun 11, 2009
Worcester - Bosch RD532 Red Signal receiver light constantly on and won't respond to control timer. Dunno if a failure or setting problem ?
Sounds like you're dealing with a pesky issue. It could be a technical glitch or just a setting hiccup. Have you tried resetting the timer or checking the settings? If that doesn't do the trick, it might be worth getting a professional to take a look.U can also check some info about alphamechanicals. They got my air conditioning installation in Orangevale, CA https://alphamechanicals.com/service-area/orangevale-hvac-service/ and as I know they has to know something about bosch devices
4/22/2024 8:16:50 AM • Bosch Water... • Answered 2 days ago
My Bosch Highflow 25 EC hot water heater loses the pendant displays on cool to cold mornings , what could be causing this annoying fault ?
Losing pendant displays on cool to cold mornings with your Bosch Highflow 25 EC hot water heater could be caused by temperature-related issues affecting the display module. Cold temperatures can affect electronic components, causing them to malfunction. It's possible that there could be a loose connection, moisture buildup, or a fault in the display module itself. I'd recommend contacting Bosch customer support or a qualified technician to diagnose and fix the issue.
2/6/2024 9:19:50 PM • Bosch Water... • Answered on Feb 06, 2024
Why is the Bosch high flow 21e system while showering going cool & then returns to the set temperature?
If your Bosch Highflow 21e hot water system is experiencing fluctuations in water temperature while showering, it could be caused by a few different factors. Here are some possible reasons for this issue:
  1. Flow rate too high: The hot water system may not be able to keep up with the demand if the showerhead or tap is allowing too much water to flow through. This can cause the water temperature to drop suddenly. Try reducing the flow rate by turning down the tap or using a low-flow showerhead.
  2. Water pressure fluctuations: If the water pressure in your home fluctuates, it can cause the hot water temperature to vary. This can be caused by various factors, such as other appliances using water at the same time, or changes in municipal water supply pressure. Installing a pressure regulator or a flow restrictor may help to stabilize water pressure.
  3. Blocked or dirty water filter: A clogged or dirty water filter in the hot water system can restrict water flow, causing the water temperature to fluctuate. Check the filter and clean or replace it if necessary.
  4. Malfunctioning thermostatic mixing valve: The thermostatic mixing valve (TMV) regulates the water temperature in the hot water system. If it's faulty or dirty, it can cause temperature fluctuations. A licensed plumber or technician can inspect the valve and replace it if necessary.
  5. Faulty temperature sensor or control board: If the temperature sensor or control board in the hot water system is faulty, it may not be able to maintain a consistent water temperature. A technician can diagnose the issue and repair or replace the faulty component.
If you're unsure about how to diagnose or fix the issue with your hot water system, it's best to contact a licensed plumber or technician for assistance.
3/9/2023 3:47:20 PM • Bosch Water... • Answered on Mar 09, 2023
My old tankless naturMy gas water heater Bosch model JSRZ 5-T PG, it is not starting automatic it has magnetic sensor valve in water inlet
The Bosch JSRZ 5-T PG tankless gas water heater may not start automatically because of problems with the magnetic sensor valve, power supply, or control unit/thermostat. Possible troubleshooting steps are:
  • inspect the water inlet valve and replace if faulty
  • confirm that power to the unit is functioning
  • if the problem continues, seek professional repair service.
1/29/2023 11:17:51 AM • Bosch Water... • Answered on Jan 29, 2023
No water coming out of hot water taps with a Bosch Water Wizard 10P?
Do you live in a climate where the hot water line could have frozen? If your heater did freeze up, that could be very bad. This is because water actually expands when it freezes and can do a lot of damage to pipes and to the water heater itself. My other thought is possibly a clogged in line water filter. But typically a clogged water filter would make it run with reduced pressure rather than a complete shutdown all water flow.
1/20/2023 6:10:26 AM • Bosch Water... • Answered on Jan 20, 2023
Can you help with these Bosch 715 EFS GWH Error Codes? AF, 40, 07 -
https://www.fixya.com/support/t13643459-a2_af_error_codes
1/10/2023 7:22:20 PM • Bosch Water... • Answered on Jan 10, 2023
Bosch Ariston GL4 GL4 Point-of-Use Electric Mini-Tank Water Heater Logo
14 questions posted
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Bosch Water Heaters
  • Bosch Water Heaters
Most Popular Question
no hot water
  • Water Heaters
