20 Most Recent Lexmark Pinnacle Pro 901 All-In-One Inkjet Printer Questions & Answers
2answers
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
10/1/2021 9:08:59 AM • Lexmark Pinnacle... • Answered on Oct 01, 2021
How do I bring the printer out of the power save
Usually, pressing the power button, brings the printer out of power-save mode. Sometimes, the printer gets hung. If this happens, disconnect the power plug, wait 30 seconds and reconnect power.
10/30/2015 4:11:16 PM • Lexmark Pinnacle... • Answered on Oct 30, 2015
Black ink tank is full-printer says empty!
Run a head cleaning mode this will usually fix the problem. If the machine hasn't been used for a while you might have to get in there with a q-tip a denatured alcohol and clean it.
10/22/2015 5:33:31 AM • Lexmark Pinnacle... • Answered on Oct 22, 2015
What to do when message appears, "lexmark web gateway" has stopped working?
Try reinstalling the software that came with it or download and reinstall the the driver from the lexmark website.
5/13/2014 11:17:02 AM • Lexmark Pinnacle... • Answered on May 13, 2014
Can not connet to print
make sure power is on, cable is plugged in between printer and computer, and that the driver is loaded on the computer.
11/27/2013 11:33:13 PM • Lexmark Pinnacle... • Answered on Nov 27, 2013
Printing a confirmation sheet after every page is faxed
Navigate to the Settings on the Printer itself, Under Settings there would be a column which would say Fax settings, Under that you would see an option to Turn it Off!!!!!Good Luck!!!!!
5/13/2013 6:23:20 PM • Lexmark Pinnacle... • Answered on May 13, 2013
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
9/7/2014 8:30:44 PM • Lexmark E Office... • Answered on Sep 07, 2014
0answers
Lexmark Pinnacle Pro 901 All-In-One Inkjet Printer Logo
33 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
when message appears lexmark web
  • Office Equipment & Supplies
