20 Most Recent Samsung CLX-3305FW Color Laser Multifunction Printer Questions & Answers
remove all toners and on the left hand side is the waste ink container. You should be able to simply remove. and yes you will have to order a new one, or try and empty that one
Samsung... | Answered on Nov 18, 2015
1st don't wear a new shirt when doing this !!!!
waste toner tanks are not meant to be reused (not saying you couldn't ) but its gonna make a mess doing it so id choose not to do iinside the office that's for sure , replacement tanks are available from same sources you buy toner cartridges from then just tape up the spout and toss old one away , some machines will require a manual reset of toner tank alarm , consult your manual to see how you do it
and if your dead set on cleaning it , what id do is buy one new one install it and take old one outside in a field miles from nowhere using 91% isopropanol alcohol and a hand full of old rags (disposable gloves too) id wipe it clean ,then store it under machine in paper storage box (not tray) so its there ready to use next time you need it
Samsung... | Answered on Sep 17, 2015
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Samsung... | Answered on Mar 17, 2015
Insufficient information to answer the problem. Try going directly to their web site http://www.samsung.com/us/search/espsearch.us?keyword=CLX-3305FW+ and check the SUPPORT and FREQUENTLY ASKED QUESTIONS section
Samsung... | Answered on May 04, 2014
Go to System Preferences--> Print & Fax-->Under Printers click the + button and add the printer to your queue
Samsung... | Answered on Aug 04, 2013
You should try feeding one sheet at a time and make sure u are using paper that is compatible
Samsung Office... | Answered Yesterday
Changing the Display Language and Country
Setting Language
To change the language that displays on the control panel,
follow these steps:
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) until "Language" appears
on the bottom line of the display.
3 Press Enter. The current setting appears on the bottom
4 Press the scroll button ( or ) until the language you
want appears on the display.
5 Press Enter to save the selection.
6 To return to Standby mode, press Stop/Clear.
Setting Country
of the display.
2 Press the scroll button ( or ) until "Select Country"
appears on the bottom line of the display.
4 Press the scroll button ( or ) until your country appears
on the display.
NOTE: Changing the country clears the memory.
Link to manual
http://h10032.www1.hp.com/ctg/Manual/c05786751
Samsung Office... | Answered 2 days ago
You can download the drivers/User Manual from the Samsung Official Support site. Here is the link for Samsung SCX-4521F. Click Manual, download and refer to Section 7, Page 38 onwards for detailed instruction about setting up fax. Also you can click Drivers, select Operating System and get the drivers/ software
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Samsung CLX-3305FW Color Laser Multifunction Printer Logo
11 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
connect printer imac
  • Office Equipment & Supplies
