20 Most Recent
Price Pfister Universal 0X8-310A Pressure Balanced Rough-In Valve for Tub Questions & Answers
I installed a new Price
No and you can thank you government rep next time you see or talk to him for this. The valve is set to give no more than 110 to 115 degree water and cannot be changed. If you want hotter water you will need to install a non-scald faucet. Now if you are not getting to the 110 degree mark then you will need to disassemble the valve body and look for debris in the hot water inlet side.
Now when it is apart turn the water on low and flush the piping out before putting it back together.
Installed new presure cartridge.
I would recommend going to a hardware or plumbing store and picking up some "hammer arrestors" to put on your washing machine valves, this can help with that. This pipe banging can be due to pipe strapping that has come off but is most often caused by excessive water pressure.
HELLO THE FAUCET DRIPS AT
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy.
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
