20 Most Recent
Price Pfister Centerset Lavatory Faucet SATIN NICKEL Questions & Answers
How do i disconnect the sprayer connection in
There should be a ring around the female portion of the quick connect that pushes in allowing you to remove the male portion of the assembly.
If you are having trouble pushing it in use a set of adjustable pliers set to the size of the exterior ring to push it - it will be easier than using your fingers.
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy.
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
What causes noise when water turns on
are you speaking of water hammer ? as typically this occurs when shutting off water , faucets that make noise like a whistle when on could be a part clogged aerator in the end of it , this happens over time and debris is aloud to collect in end of faucet
