20 Most Recent Price Pfister 42-YP0E Ashfield Single Control Lavatory Faucet With Pop-Up Questions & Answers
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Price Pfister... | Answered on Jan 04, 2012
How are the other faucets in house working hot water wise .. often the 3/4 nipple plug's up just as it comes out of water heater . if other faucets OK the i have found the clog in the stop / valve feeding the hot side shut off water to house or shut off hot water at heater pull your stop & check it out ..if problem emanates from water heater replace or take screw driver & **** out nipple.. at w/h ..
Price Pfister... | Answered on Apr 04, 2011
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Price Pfister... | Answered on May 15, 2019
1 under the sink turn off both water supplies
2 disconnect the supply lines at the on/off valve EZer than at faucet
3 under sink unscrew the retaining nut(s)
4 on top wiggle or pry the faucet and lift up and remove.
5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring .
6 Reinstall check for leaks
7 caulk around faucet.
Hope this helps Mike
Price Pfister... | Answered on May 31, 2018
Back to the basics...did you turn the hot water shutoff back on? Is it a multi-turn shutoff or a 1/4-turn one? If it was old, and multi-turn, the washer could be shot, and it is all clogged. Try disconnecting the hose and see if you can get any flow into a bucket from the connection.
There could be some crud caught inside of the cartridge, so you might need to remove it and flush it out. Price Pfister single handle sink faucet no hot water
Price Pfister... | Answered on Feb 12, 2018
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy.
aaaaaelftksuqmccaa==
Price Pfister... | Answered on Dec 30, 2017
take the old one to the store with you they can match it up.. (home depot... lowes)...
Price Pfister... | Answered on Oct 02, 2017
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
Price Pfister... | Answered on Jun 14, 2017
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Price Pfister... | Answered on Jan 08, 2017
dry rubber "O" ring/ threads on the shaft
call a plumber to pull it apart , replace the seal and lubricate it
Price Pfister... | Answered on Dec 04, 2016
Price Pfister 42-YP0E Ashfield Single Control Lavatory Faucet With Pop-Up Logo
4 questions posted
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Price Pfister Plumbing
Most Popular Question
just purchased price pfister 42 yp hot
  • Plumbing
