20 Most Recent
PC Chips M925ALU Motherboard Questions & Answers
Sorry I have no book,
Download manual from the manufacturers website in pdf format and then read carefully
Do I need to upgrade my board to play games like
yes it is necessary. there are many boards available for sale. you can contact your local computer dealers are the best ones for you because as a matter of fact, it depends on the game you choose to play. different games work better on different boards.
hope this answered your question? please rate
M925 v7.3 motherboard manual
I was able to find a website that has the specifications for this board, hope that will help you.
Click
here.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
I want to clear a password that the computer as fo...
this is simple just remove the left hand side of your case and there will be a round battery on your motherboard usually near the bottom this is whats stopping the motherboard from losing that password as it powers the bios chip to stop your bios from resetting every time your PC is turned of so just remove that for a minute then put it back and the password should be gone when you turn your computer back on hope this helped
MotherBoard pcchip M925ALU Rev.5.0A is not
In this case you need to check of the memory is good try to use another memory if you have. Remove the memory stick and try to turn in on. Is the unit beeping, reinsert the memory stick try to use the other memory slot. Clean the memory with the use of eraser. First cause of beeping is the memory problem. For more instructions you can refer to the link below
http://www.computerhope.com/beep.htm
LAN connection problem
That means connection has been established but not the ADSL. Ask you ISP to provide the current DNS addresses, gateway & IP if your IP is a static IP address...............sodeep
What is embedded system?
- An embedded system is a computer system with a dedicated function within a larger mechanical or electrical system, often with real-time computing constraints. It is embedded as part of a complete device often including hardware and mechanical parts.
read all about it.
Embedded system
3/6/2024 4:40:49 AM •
PC Chips...
Answered
on Mar 06, 2024
I have a pcchips p21g v1 motherboard, but it wont
Is that one of the PCChips boards that has a jumper to enable/disable writing to the BIOS (Basic Input Output System? If it has a hard drive in it, disconnect or remove the hard drive, and then reset the BIOS, by removing the BIOS battery for 5 minutes, then put the (good?) battery back in, and boot it up without any hard drive. I have seen such behavior before, due to malware such as TDL4, and also "BadBios!" Those malware systems can OVERWRITE any unprotected BIOS with modified code!
4/26/2017 8:05:43 PM •
PC Chips...
Answered
on Apr 26, 2017
Emx 945gc 1333
http://www.free-4all-download.com/downloadnow/download+emaxx+emx-mcp61M2-icafe+v2.0+driver+free+download
5/21/2014 6:12:29 AM •
PC Chips...
Answered
on May 21, 2014
