20 Most Recent
PC Chips M863G V3.0C W 3400+ (ATHLON 2600 MHZ) 166MHZ FSB W FAN (M863GV30W3400) Motherboard Questions & Answers
http://www.pcchipsusa.com/PCCWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=343&DetailName=Feature&MenuID=1&LanID=0
Please i need the sound
Try this WEB site -
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0
I HAVE NO SOUND AND THE USB D`ONT RECOGNIZE ANY
control panel sounds and audio,audio you will find the necessary adjustments to make there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
Manual doesnt show Ieee 1394
You can buy an add-on Firewire (IEEE 1394) card in one of the two PCI expansion slots. That would add the firewire port on the back of the computer.
HD w/Serial ATA cable
The M863G V3.0 motherboard doesn't support SATA drives directly, so you'll need an adapter between the SATA drive and the IDE connection on the motherboard. Some of these adapters are a little bulky, so make sure you have enough room. Also, you'll need a spare power connection for the adapter. Good luck!
What is embedded system?
- An embedded system is a computer system with a dedicated function within a larger mechanical or electrical system, often with real-time computing constraints. It is embedded as part of a complete device often including hardware and mechanical parts.
read all about it.
Embedded system
3/6/2024 4:40:49 AM •
PC Chips...
Answered
on Mar 06, 2024
I have a pcchips p21g v1 motherboard, but it wont
Is that one of the PCChips boards that has a jumper to enable/disable writing to the BIOS (Basic Input Output System? If it has a hard drive in it, disconnect or remove the hard drive, and then reset the BIOS, by removing the BIOS battery for 5 minutes, then put the (good?) battery back in, and boot it up without any hard drive. I have seen such behavior before, due to malware such as TDL4, and also "BadBios!" Those malware systems can OVERWRITE any unprotected BIOS with modified code!
4/26/2017 8:05:43 PM •
PC Chips...
Answered
on Apr 26, 2017
Emx 945gc 1333
http://www.free-4all-download.com/downloadnow/download+emaxx+emx-mcp61M2-icafe+v2.0+driver+free+download
5/21/2014 6:12:29 AM •
PC Chips...
Answered
on May 21, 2014
