20 Most Recent
Toshiba RDXV60KB DVD HDD VHS Recorder Questions & Answers
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
How do I record from DVD to HDD
DVD player AV out to HDD AV in RCA cable red white yellow
HDD input source has to be AV in you may have to set up a timed program chanel to av in av1 or av2
you may not be able to do this due to copyright embedded signals being detected by the HDD
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM •
Toshiba...
Answered
on Apr 07, 2024
