20 Most Recent ColorApples Chunghop RM-50 Universal InfraRed IR Remote Controller TV/VCR/SAT/CBL/DVD Questions & Answers
2answers
Code for promac dvd player
091,096,094. Try these codes. For more information, check these links. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
3/20/2020 10:41:35 PM • ColorApples... • Answered on Mar 20, 2020
What is the code for Nippon tv using a Chunghop remote control?
0932,0956,0918,0933. Check these codes. If you wish to get more details, check this site. Pull up previous posts. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Code list to Chnghop and many other brand remote controls are given. Check this site too.
8/18/2016 8:38:09 PM • ColorApples... • Answered on Aug 18, 2016
I have a Chunghop RM-L969 and i need the code to use it for a vcr aiwa (FX5850).
Chunghop remote control have no set-up code to Aiwa VCR. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
9/8/2015 12:32:56 PM • ColorApples... • Answered on Sep 08, 2015
Can chunghop remote paired tecovision compatible
Check whether there is a set-up code to your TV brand with this remote control. If yes; you can. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/
10/29/2014 7:20:13 AM • ColorApples... • Answered on Oct 29, 2014
Code for promac
0482,0481,0488. Try these codes. For more information, check these links. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
11/17/2013 5:02:19 AM • ColorApples... • Answered on Nov 17, 2013
2answers
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
The most obvious reason is an overheating issue in the Power Supply board. There are other ideas here, but you need to take it to a television engineer to diagnose https://www.google.com/search?q=television+will+suddenly+turn+off+every+4+minutes ..
4/24/2024 6:22:38 AM • Televison &... • Answered 18 hours ago
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/23/2024 11:02:30 PM • Televison &... • Answered Yesterday
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered 2 days ago
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered 3 days ago
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered 3 days ago
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered 3 days ago
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered on Apr 20, 2024
JVC KW-AV50 DVD receiver. None of the volume Up or Down buttons work JVC KW-AV50.
Try cleaning behind them with electronics switch cleaner spray, but it may be the whole module is faulty. https://www.google.com/search?q=jvc+kw+av50+volume+button+not+working ..
4/20/2024 6:31:28 PM • Televison &... • Answered on Apr 20, 2024
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered on Apr 19, 2024
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered on Apr 19, 2024
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered on Apr 19, 2024
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered on Apr 19, 2024
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered on Apr 19, 2024
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered on Apr 16, 2024
ColorApples Chunghop RM-50 Universal InfraRed IR Remote Controller TV/VCR/SAT/CBL/DVD Logo
7 questions posted
Top ColorApples Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a ColorApples Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ColorApples Televison & Video
Most Popular Question
code promac dvd player
  • Televison & Video
