20 Most Recent KitchenAid KEMS309BSS Combination Microwave Oven 30""" Questions & Answers
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
KitchenAid... | Answered on Feb 24, 2016
Yes, unless a technician may have removed it during a previous service. It should be located behind the controller assembly, sometimes in a small envelope.
At my Web site, I have a video showing you how to remove a typical microwave controller in about 5 minutes.
http://www.microwavecontrol.com
if you have other questions, please feel free to contact me directly by email through the Web site or at pupista@gmail.com
KitchenAid... | Answered on Nov 14, 2019
Yes, it is probably a bad relay. Usually appliance techs just replace the whole control board, because those relays can be hard to find and buy.
KitchenAid... | Answered on Oct 14, 2019
Yes, it is most likely a bad relay on the control board.
KitchenAid... | Answered on Oct 05, 2019
Hi Jill, what the screen indicates is that the door is not closed
There are a number of internal contacts that have to be closed for the microwave to work
If any of them are wrong, they can give you that information.
Depending on the brand there may be between 2 or 3 contacts in the door area that generate that warning
Indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Jill, lo que te indica la pantalla es que la puerta no esta cerrada
Hay una serie de contactos internos que tienen que estar cerrados para que el microondas funcione
Si alguno de ellos esta mal puede darte esa informacion
Derpendiendo de la marca pueda haber entre 2 o 3 contactos en la zona de la puerta que generan ese aviso
Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
KitchenAid... | Answered on Sep 12, 2019
There are interlocks and micro-switches to prevent accidental running with the door open. The issue with the lock is preventing operation. You need to have it professionally serviced.
KitchenAid... | Answered on Sep 09, 2019
You can find helpful Kitchenaid parts diagrams and get parts at affordable prices for most models from The Pros by entering your model number here:
http://tinyurl.com/gv383
KitchenAid... | Answered on Jun 30, 2019
For the KitchenAid microwave, model: KHMS2050SSS2 I found that i did not have to remove the screw. what i did was loosen the screw as much as it would go before getting tight again.(hard to screw) then on the bottom end of the door hinge (lying on its side) i pryed the bottom hinge off its mount. (with flat head screwdriver) from there i was able to get at the screws to separate the black surrounding stuff from the outside door... then finally i could get inside to get at the door panel controls. I noticed a whole bunch of condensation and on the back of the touch panel (electrical board).. i will replace that part as I think that is the culprit as to why the keys get pressed randomly, beeping randomly and wonkiness :)
KitchenAid... | Answered on Mar 15, 2019
Adjust the door switch mounting strip as adjustment is provided if not o.k check door switch connector on the PCB assembly for loose contact or soldering.
KitchenAid... | Answered on Mar 05, 2019
KitchenAid KEMS309BSS Combination Microwave Oven 30""" Logo
4 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
runs 20 sec stops reads f1e5
  • Microwave Ovens
